silencer ring
Old May 27, 2003 | 10:41 PM
jlboren's Avatar
silencer ring
Iam new to this so I need to ask this how do you remove the silencer ring and what exactly does it do
Old May 27, 2003 | 11:03 PM
Mostwanted's Avatar
Re:silencer ring
Silencer ring quiets down the whistle heard from the turbo. Removal is easy- just pull off the big piece of tubing that goes into the front of the turbo. In the front part of the housing you will see a snap ring encircling the inner cirumfrince of the housing. Use a couple of screw drivers and maybe a pair of needle nose pliers to pry this ring out. Then you will see a round metal ring that will pull right out, that is the silencer. Remove it then put the intake hose back on and you are ready to go. AAHH!!! your first step to blisful bombing! ;D
Old May 27, 2003 | 11:19 PM
Stamey's Avatar
Re:silencer ring
Keep in mind it only makes the turbo louder. There is no performance gain from this modification.<br><br>Chris
Old May 28, 2003 | 12:26 AM
jlboren's Avatar
Re:silencer ring
sounds easy anything for more noise the more noise the better thanks
Old May 28, 2003 | 12:47 AM
SmokinDodge12V's Avatar
Re:silencer ring
If you havent allready done this, I would get rid of the stock air filter housing and get an BHAF of AFE filter then you will really hear that turbo scream. ;D
Old May 31, 2003 | 03:46 PM
Drafter's Avatar
Re:silencer ring
Removed my silencer ring at the same time I did the first oil change. My friend showed me how it is done so I am passing on the information with some pictures to illustrate.<br><br>The written steps mentioned above give the detail needed so just look at the pictures to see what they are talking about.<br><br>Hope this helps.
Old May 31, 2003 | 03:49 PM
Drafter's Avatar
Re:silencer ring
Once the tubing is removed you can see into the front of the turbo and that is where you will find the silencer ring and retainer ring. Keep in mind that in this picture the silencer ring is already removed.
Old May 31, 2003 | 03:50 PM
Drafter's Avatar
Re:silencer ring
This final picture shows what the silencer ring and retainer ring look like. Removal of the silencer ring will definitely give you a whistle.
Old May 31, 2003 | 11:42 PM
Mostwanted's Avatar
Re:silencer ring
For more noise, besides the airbox, loose the exhaust!! ;D
Old Jun 1, 2003 | 12:09 AM
trailrydr9's Avatar
Re:silencer ring
I second the exhaust coment, and will add, put on a scotty filter and cut out the hole, and really hear the turbo scream.
Old Jan 25, 2004 | 05:41 AM
Fishbait's Avatar
Fantastic Pictures.................Some off us ADD folks sure appreciate pix! Kind of puts all the explaining together..............Thanks!
Old Jan 25, 2004 | 10:05 AM
ramcamping's Avatar
two things (1) does the scotty filter use the same air box and (2) is the k&n filter any good
Old Jan 25, 2004 | 10:12 AM
dieselcrazy's Avatar
you may have opened a can of worms with the k/n question..... i have the k/n and have no problems with it at all. i also had the chance to switch out to a BHAF hoping to hear the turbo scream more and i noticed no difference. im not saying anyone else is wrong, just telling my experience. im not sure what you are asking about the scotty but i hear the scotty II with the hole cut really livens up the turbo noise. good luck, scott
Old Jan 25, 2004 | 10:16 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Ramcamping,
I used the K&N for a few years, didn't like the "Gotta use grease to TRY to get it to seal" game.
K&N is now sitting on the shelf.
Went with a Scotty II......no more problems/worries, as an added plus reduced my EGT by about 50*.
Guys who tow heavy and/or are seriously BOMBed should see greater reductions.
Old Jan 25, 2004 | 10:22 AM
shovelhead ....... is it true what i have heard........ did the turbo noise increase enough to notice ?? do u have the hole cut ?? .. thanks, scott
