Schematic for T/C lockup switch...found it!!
Old Jul 30, 2005 | 04:39 PM
I SPEED's Avatar
I found it.....Mystery switch schematic
This is the way I wired mine...works great.
edit...you still need to jump the trans. relay in fuse box under the hood.
Old Jul 30, 2005 | 06:46 PM
got...DIESEL?'s Avatar
Glad you like it nospin.....I drew that quite a while ago, but the RE crowd needed to make some mods to it as I was RH with a different lock-up circuit than you RE guys (relay). Otherwise, should work flawlessly.....no more absent mindedness stalls. nyone who sais they haven't done it with a mystery switch is lying
Chris
Old Jul 30, 2005 | 07:38 PM
Big Deezul's Avatar
I suck at reading schematics...is there anyway you coulc do a step by step on it?
Old Jul 30, 2005 | 07:48 PM
I would, but seeing that you have an RE trans, I would think Doug would be better to outline it because he adapted my original RH drawing for an RE system. Let me know and I'll help further if possible.
Chris
p.s. If you're still waiting for the trans to go out , the lock-up switch will help that along quite nicely, depending on how you intend to use it!
Old Jul 30, 2005 | 09:06 PM
I SPEED's Avatar
Chris
Hey Chris...now I know who to thank!!
As far as a step by step write up for this, I'm not the one to do that. I followed the schematic and was still second guessing myself. Works on my 2001 perfectly.
Old Jul 31, 2005 | 04:14 AM
loveturbowine's Avatar
What exactly does this lock up do for you? Better mpg, power, what?
Old Jul 31, 2005 | 02:18 PM
marks2500's Avatar
man, i was almost on my way to the store to buy the parts when i read the schematic above is only for the rh not the re how can i build one for the re?
Old Jul 31, 2005 | 02:31 PM
I SPEED's Avatar
I've got this setup in my 01 without any trouble. Wired per the schematic.
Old Jul 31, 2005 | 02:41 PM
marks2500's Avatar
hey nospin4me,
what tranny do you have in your truck, RE or RH? the above states it will not work on a RE without altering the schematic
Old Jul 31, 2005 | 04:45 PM
bmoeller's Avatar
'94-'95 trucks=47 RH
'96-'02 (and some '03s)=47 RE
This is from Infidels gallery-
Old Jul 31, 2005 | 04:54 PM
bmoeller's Avatar
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Old Jul 31, 2005 | 06:17 PM
I SPEED's Avatar
I'm looking over the schematic and maybe I need to have my glasses checked, but I do not see where it says RH only.
There is one thing I did have to add...a 4th relay. Between the TC lockup output wire coming from the top relay and the TC lockup wire at the PCM. IIRC it was backfeeding through and causing one of the 3 relays to chatter. So it had to be isolated with the 4th relay.
If this is what is meant by having to modify schematic for the RE, then yes, I had to modify.
Old Jul 31, 2005 | 08:57 PM
marks2500's Avatar
nospin4me,
ok so i buy a 4th bosch 5 terminal relay, do i still have to run +12volts to terminal 85 (like the rest of the relays) - ground 87? or 30? and run terminal 86 from the TCR relay to the new relay 86 and back out witch terminal to the PCM wire? WOW i have no idea how to add the 4th relay to 3 that are already there mabe you could explain how to wire in the 4th relay thanks
Old Jul 31, 2005 | 11:14 PM
bmoeller's Avatar
A diode would solve that problem, too.
Old Aug 1, 2005 | 06:18 AM
I SPEED's Avatar
nospin4me,
Ground 87, 12V to 85, TC lockup wire from the top relay in the schematic to 86, and 30 will go to the TC lock up wire at the PCM.
I tried a diode and where this cicuit is triggering a ground it would not work.
