recommended upgrades
Old Mar 23, 2008 | 06:34 PM
coppertop02's Avatar
i got a 2002 ctd quad cab short bed and all i got is a 4" mbrp ss w/ 5" tip what programmer/box, intake, and gauge setup should i use without having to do anything to the stock tranny
Old Mar 23, 2008 | 06:47 PM
swmnkdinthervr's Avatar
There are several choices of gauges...just make sure you get a fuel pressure gauge...It seems Quadzilla is the only manufacturer not forgetting the 2nd Gen trucks,,,you can't go wrong with their products and their customer service is second to none! Unfortunately anything more powerful than an XZT+ will KO yer tranny...
Old Mar 24, 2008 | 05:43 AM
smokinram99's Avatar
got a fuel pressure gauge and EGT FIRST! look for QUAD XZT+ EDGE EZ but I think is a better choice upgrade the fuel system before any add on
you have a MBRP(more air out) you need more air in, so an intake will breath up you cummins, many good intake AFE(higher price) and S&B my first choice
Old Mar 24, 2008 | 06:02 AM
j-fox's Avatar
Get the gauges!! Also for best mileage get some Mach 1.6 injectors. If you cannot afford them get the 275 injectors.
Old Mar 24, 2008 | 07:53 AM
91rangerturbo's Avatar
For sure get a Boost,EGT, and fuel pressure gauge. If you can get a tranny temp gauge. That is all you will ever need.
Old Mar 24, 2008 | 12:22 PM
thanks for all the help guys. i was considering the superchip so i could recalibrate the speedometer for bigger tires and still get managable power for my truck. any comments on the superchip?
Old Mar 24, 2008 | 12:55 PM
I had one and it was nice for the tire recalibrate. But i got bit by the diesel bug and sold the superchips and bought a wire tap box like the Edge Drag Comp. It all depends on what you need?
Old Mar 24, 2008 | 01:00 PM
well im only 16 and i live on a farm so i want something that wont hurt my tranny, and that i can pull stuff around with. we have 1000 gallon water tanks that loaded will weigh about 10000 pounds or so. and a chip that can help me goin down the eighth at dunn/benson but still be useful
Old Mar 24, 2008 | 01:51 PM
Then get the superchips for now. You would like it. And check around first before buying a new one. you can get a used one for 250 or less.
Old Mar 24, 2008 | 01:56 PM
Bjans's Avatar
throw a s&b intake on there. (best for the price) then reposition the lift pump or add another to the frame wether it be a fass or holly or whatever you want. then do guages and a poere adder of some sort. superchips is ok but not that great. It won't give you very much
Old Mar 24, 2008 | 06:09 PM
also ive been lookin at gettin a boost elbow for my turbo but where does it fit and does it even work on the hy35, and also why would i need a fuel pressure gauge
Old Mar 24, 2008 | 08:37 PM
1BAD4X4's Avatar
No the boost elbow doesn't work with the HY, you need a J-hook or something similar for the HY.
You need a fuel pressure gauge because the injection pump(VP44) and the stock lift pump on the 24v trucks are known for failure, especially when performance parts are added. A fuel pressure gauge is a MUST have for any VP44 powered truck.
Old Mar 24, 2008 | 08:49 PM
high bid's Avatar
I have a s-chip right now programmed on my truck. It does run like crazy and has power but I'm ditching the program and installing the xzt+(adjustable). With all of the different dloads avail thru Quad, I hope it will be a good choice, because there's no going back once it's reflashed. Yes, make sure you have a fuel pressure gauge and EGT.
Old Mar 24, 2008 | 09:55 PM
thanks guys im still kinda short on money so should i get the chip or the gauges first?
Old Mar 25, 2008 | 08:44 AM
Goalie990's Avatar
gauges first.. u need to monitor them with the chip
