quadzillia xilliader and zxt?
Old Mar 7, 2007 | 08:56 PM
oldblu's Avatar
i am getting ready to purchase a quadzillia module and had a few questions. first off do either one increase or play with the pump pressure? or just the pump timing? next are they both adjustable or just the xilliader? on this site and many more they show they are both adjustable but on the companys website it doesn't say that either one are. some help would be great. thanks
Old Mar 8, 2007 | 01:24 AM
NoSeeUm's Avatar
Check with the guys in the 3rd gen section if you have not done so.
Jim
Old Mar 22, 2007 | 04:58 PM
smokinstrokes99's Avatar
i know the zxt requires the commander digital gauge to shift on the fly
Old Mar 22, 2007 | 05:15 PM
dodgezilla04's Avatar
standard and race modules do not need the commander to shift on the fly. i have had both and just have to twist the control **** switch that came with it.
Old Mar 23, 2007 | 12:06 AM
qzilla's Avatar
Ok, on the 98-02 trucks both the XZT and the Standard modules are adjustable by themselves. You DO NOT have to get the Commander. We do this because the vp44 is totally different than the newer trucks.
All fueling mods are altering pump pressure to an extent. More than that they are extending the length of time it provides the fuel to the injectors.
Even though the XZT is only 50hp the way we do it could still give some EGT problems with heavy loads. Because the XZT needs to be 100% towing safe we added a switch so that those without gauges can knock the power down slightly and not have to worry.
Old Mar 23, 2007 | 12:57 PM
is the zxt realy only 50 hp, the web site advertised 65 hp, which is true?
Old Mar 23, 2007 | 01:11 PM
qzilla's Avatar
Sorry that should have read 60hp. I hit the wrong key last night.
The main XZT site has 65hp listed but, if you look at the actuall specs on the 98-02 boxes they will tell you 60hp. ALso it says torque is around 165 but it is close to 200-205ft lbs gain.
johna20376
Apr 22, 2008 03:13 AM
huntram
Jan 2, 2007 09:52 AM
Smithereen
Feb 9, 2006 06:19 PM
sled4fun
Jan 4, 2006 02:24 PM
