Quadzilla issue
Old Jun 9, 2009 | 12:48 PM
beeogio's Avatar
Quadzilla issue
Good morning everyone, i have an 02 cummins 5sp with a new vp44,glacier in line pump, quadzilla adr with pulse, F1 Injectors (they took a while to come in),4 in exhaust,new inj tubes. i downloaded a custom tune #20. i was having the issue where after a few min, 10 or so i would lose the inj pump (guess after reading past posts on this) so after the custom tune 20 1000 series, it lasted almost the whole way to work. After this it wasn't defueling at the right temp (actually at all) and i had lost the power(not all of it but half) i was wondering if everyone else has this issue resolved? I restarted it later, took a ride and it worked awesome which resulted in a destroyed clutch LOL the southbend is comin. Just curious where everyone else is with this, it is def. better than it was after the download.
Old Jun 9, 2009 | 02:39 PM
qzilla's Avatar
What is your serial #
Old Jun 9, 2009 | 04:15 PM
beeogio's Avatar
ser
adr 1002 59255
pcm1000 59249
Is that the correct number sir, it was on the side of the box.
Old Jun 10, 2009 | 12:45 PM
beeogio's Avatar
raise defuel egt temp
Does anyone know if i can raise the defuel temp on the pulse after downloading a custom tune on my qzilla adr. i am afraid to fool with it.
Old Jun 10, 2009 | 08:53 PM
rholbus's Avatar
You can. I think you go to hardware and you just raise it from there and save it.
Old Jun 10, 2009 | 11:02 PM
qzilla's Avatar
Ok, no issues in that lot of serial numbers.
If you are not still having the issue it was probably something to do with either de-fueling or in the custom tuning menu?
First, I would make sure you have the latest updates on both the Adrenaline and Pulse (1.3.8.0)
Second, you can change de-fuel settings anytime and it has no affect on custom tuning or what tunes you run. Even if you change tunes, the de-fueling still will remain the same.
Also, make sure when you change custom tuning it will take affect as soon as you exit out of the menu, even if you don't save it. Once you get something you like save it to Tune1 or Tune2. Once you cycle the power the tuning goes away unless you saved it and have loaded that tune back.
mopar440cu
Nov 21, 2015 08:39 PM
JonnyStraight
22
May 8, 2009 08:10 AM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
Snopczynski
May 22, 2007 11:00 PM
