Quadzilla or Edge
Old Dec 24, 2007 | 11:56 AM
danalex's Avatar
Quadzilla or Edge
I'm considering one of these modules (Quadzilla XZT+; $360 or PowerEdgeEZ; $494). This will be my first foray into performance modules so any advice/recommendation is appreciated. I don't use my truck for any heavy hauling (load of dirt/lumber from time to time), so generally I'm looking for better fuel economy & MPG. Just started using "Drew's Brew". Truck particulars are below. Looking for something easy-to-do--not too complicated. Thanks! -Dan (San Antonio)
01 2500, auto, 64K mi, Mystik JT8 15W/40, K&N air, short-bed, SLT Laramie, aprx 300 hwy miles weekly.
Old Dec 24, 2007 | 12:09 PM
BigB82789's Avatar
Quad XZT+...
BigB82789's Avatar
double post
Old Dec 24, 2007 | 12:17 PM
danalex's Avatar
Thanks! Why: easy to do, better product, ?
Old Dec 24, 2007 | 12:21 PM
1stGen545's Avatar
You cant go wrong with EDGE but I have heard good things about the Quad. I have used many many Edge products and have always had great results but I would not be opposed to trying a Quad. You can usually find them in the classifieds for a lot less $$$. They don't were out. But it is nice to have new. You should be fine with ether one.
Old Dec 24, 2007 | 12:42 PM
bullboy85's Avatar
get the XZT+, edge dosent have its max milage tune on the EZ, XZT+ can be switched on the fly, i drive on the milage tune flip it up for more power when i need/want it.
Old Dec 24, 2007 | 01:36 PM
GFB's Avatar
GFB
XZT+ fuels harder down low and you can switch from timing only to timing/fuel and even off. The quad is USB updatable for future tunes, like the high idle feature that quad will release soon. It's a great plug and play box.
Old Dec 24, 2007 | 01:39 PM
J Lent's Avatar
XZT+ for sure, better, smoother & updateable by usb. It will also have a turbo timer tune soon.
Old Dec 24, 2007 | 03:16 PM
lkuykendall's Avatar
I installed an EZ shortly after buying my 2001 and it worked great up to the day I disconnected it to install the XZT+. The peak power will be the same for either box because you can only gain so much power from a non-wire tap box but the XZT+ will provide power over a broader range of rpm as the power comes on earlier. I also like the adjustability of the XZT+ and the fact that it can be updated via USB at anytime.
I am now running the Quadzilla Adrenaline so I have an EZ and an almost new XZT+ (maybe 500 miles on it) sitting on a shelf at home. If you were a little closer to me I would just tell you to come by and test both on your pickup.
Len
Old Dec 24, 2007 | 08:16 PM
kwast's Avatar
don't know about the edge, but the xzt+ is mint!!!!!! on the fly adjustability, the ability to change programs,and high idle coming soon.......I love it!
Old Dec 25, 2007 | 08:35 PM
erics76's Avatar
Quadzilla XZT+ for all the reasons listed above. I had a Edge EZ for 4 years. The XZT+ does everything the EZ does and much much more for less $$. Sold my used EZ for almost what I paid new for the XZT+.
mopar440cu
Nov 21, 2015 08:39 PM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
sawboywv1
Sep 8, 2003 07:43 PM
