PYRO GAUGE
Old Oct 14, 2002 | 01:53 PM
bkay's Avatar
PYRO GAUGE
Will be installing my pyro, boost, and fuel pressure guage this week. Should the pyro be before or after the turbo, or does it make a difference?
Old Oct 14, 2002 | 05:35 PM
chuck3's Avatar
Re:PYRO GAUGE
Yes it makes up to 300 deg difference. I have mine after the turbo ( post ) but I'm going to change it to ( pre turbo ) before turbo, This will give a more accurate reading with out having to try to figure how much temp to add to the post reading.
Old Oct 14, 2002 | 06:46 PM
ATEAV8GN's Avatar
Re:PYRO GAUGE
Bkay,<br><br>I'm gonna go along with what Chuck said.. mines measuring post right now, but I'm gonna move mine to pre-turbo as soon as I get a chance.. probably when I help you install YOURS <br><br>
Old Oct 15, 2002 | 08:19 AM
bkay's Avatar
Re:PYRO GAUGE
Pyrometer Installation Dodge Cummins Turbo Diesel<br>Manifold Installation <br>See Universal for Installation on Turbo Down Pipe<br><br>1. Remove turbo from exhaust manifold.<br><br>2. Stuff a small shop towel or rag 4 to 5 inches into the rear exhaust manifold passage (see pic below) through the turbocharger mounting flange. This is to prevent chips from entering the manifold while drilling and tapping.<br><br>3. Drill through the exhaust manifold into the rear manifold passage. Use a 7/16&quot; drill bit and keep the drill perpendicular to the manifold surface.<br><br>4. Tap the drilled hole with a 1/4&quot; NPT pipe tap. Check the thread depth as you tap by periodically removing the tap and screwing the probe fitting into the tapped hole. The probe should thread 3 to 3 1/2 turns hand tight. Do not install the probe in place at this time.<br><br>5. MAKE SURE THE RAG IS REMOVED FROM THE EXHAUST MANIFOLD. Also remove as many loose chips as possible left in the exhaust manifold. A shop vacuum or small brush may help.<br><br>6. Install the probe in the manifold. (Anti-seize on the threads is recommended)<br><br>7. Continue to hook up the pyrometer per instructions in the universal install.<br><br><br><br> <br>
Old Oct 15, 2002 | 05:55 PM
chuck3's Avatar
Re:PYRO GAUGE
bkay, not many people remove it. Use grease on drill bit, have a vaccume handy, drill slow and remove fillings often, and use a magnet to collect any that might have fallen into manifold.
Old Oct 15, 2002 | 06:32 PM
NWDave's Avatar
Re:PYRO GAUGE
What Chuck said. That's the way mine was done, by some friends who have done many of these pre turbo installations. Lottsa grease on the drill bit, good vacuum next to the bit while drilling slowly, then a thin magnet to reach into the hole to pick up any strays. Mine's been done now for about a month and nary a problem. Take your time, piece of cake.<br><br>~Dave
dzl_damon
Jun 7, 2009 06:28 PM
Igor
Sep 13, 2005 12:47 AM
barracuda
30
Apr 22, 2003 05:55 PM
Garz
Dec 8, 2002 08:29 AM
