Projects
Old Feb 18, 2006 | 06:47 PM
gmctd's Avatar
Cool Projects
Hi folks - thought you might like to hear 'bout my truck.
I picked up a '96 3500 club cab Dodge\Cummins 5-spd 2wd dually which I've been er, um, slightly busy with, instead of posting, here, there, and everywhere.
So far, I've added IAT, Boost, and EGT gages, replaced the clutch-pilot bearing (already had a new clutch\pressure plate, t-o bearing), installed the 330hp\750lbsft torque TST plate, replaced the brown doggie-motel velour interior with grey velour, instrument panel and all, replaced the vacuum brake boost with Hydroboost, and.......
Dodge built their frames in three sections -
front section determined suspension type
2wd independent
4wd coil springs, trailing links
2wd straight front axle coil springs\trailing links, same frame\suspension\steering as 4wd
middle section determined cab type
regular cab 2-door
club cab 2dr (4 door '98 - up)
rear section determined bed length
Sooooo......I jacked the truck up, raised the cab up a foot off the frame, raised the Cummins 6 inches outta the frame, then cut the front i-f-s frame section out at the factory splice, directly beneath the seats.
Having located and prepped a '98 3500 4wd frame section and 2001 straight front axle, I then mated, aligned, and welded the two sections and VOILA!!!
I now have maybe the only Dodge 3500 HD straight front axle dually pickup on the road - white\grey velour, sittin' 5" higher than when Dodge sold it to another old man and his dog (Boy! did that cab ever stink!!!!!).
The straight front axle is the Dana 70 without the differential third-member and drive axles - the steering knuckles, brakes, hubs, etc, are the same, just no drive assy, replaced by a section of 3/8ths inch thick heavy-wall tube.
HD factory option was offered only in cab-and-chassis configuration, with the narrower rear axle
I see Dodge now builds one-piece rail frames, but I like the '93 - 2001 body style trucks, so no biggie.
Next is a '98 4-door club cab switcheroo, a 2002 NV-5600 6-speed with 13" clutch to handle the 750ftlbs torque, maybe an 8.3 with TST for 1300ftlbs torque, and you should see what can be done with the first-gen 24-valve by eliminating the PCM.
Hoo hah!!!!! did I mention I like Dodge\Cummins?
BTW - it's gettin' 21mpg back and forth to work, 30 - 45mph, stop lights, traffic, and all, and those long-travel coil springs give it 1/2-ton-smooth ride characteristics.
All-in-all, a really satisfying conversion.................
__________________
tdp member #1505
BC847
Jun 9, 2006 11:38 AM
2500CTD
Dec 9, 2004 06:58 AM
y-knot
28
Feb 18, 2004 03:42 PM
