Projector lights for 94 up pics
Man 6 pages and I still can't find an answer to my questions!
I am looking for:
Replacement PROJECTOR housings
Adjustable
High/Low beams
HID - can support HID
Euro spec a plus (not STYLE, but meets Euro specs)
Doesn't look like import Honda trash. Do these exist?
I am looking for:
Adjustable
High/Low beams
ok i have them. it is the hole housing not just the projector. you can replace the bulb but not the projector housing. you can adjust them like any headlight, it has high beam but they are regular bulbs (9005), lows are the projectors in it, i don't know if it can suport hid lights, i don't knoww what you are asking on the euro spec
I think what I'm going to do is buy a set of sport lights, throw some silverstars in the 9007 slot, and get an HID kit from xenondepot.com for the 9004 slots. To me that certainly seems like the best/brightest option. I'll wire the low beams to come on when the HID's do, and I'll have to wire in a relay off the highbeam switch to turn on the highbeams in the 7's.
I Installed a set just before Christmas. They're great, but I did have to pop the pins on the light harness and switch the ground and low beam wire positions to get everything to work right. My only complaint would be that they don't quite fit as good as the stock lamps where the corner lamp mates to the fender, otherwise they fit and look great and were easy to install.
One tip, just go ahead and loosen up the bumper and let it drop. I was able to fight the drivers side and get it in, but I fought the passneger side for an hour before finally dropping the bumper. Also be sure to do all you headlight alignment before realigning the bumper. You'll probably find you'll need to pull the lamps again to realign the high beams.
www.puredieselpower.com has the lights for sale!!!
With ebay, you never know what you're gonna get.
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
