Poweredge
Old Jul 23, 2004 | 05:36 PM
Mike Lyons's Avatar
Poweredge
Hi,
I have a Poweredge controler that was removed from a used Dodge pickup. The truck was sold and I have no information on year. The control has three LEDs on the front and an on/off switch. It has the following numbers on the back, 99SDT.2 and 141175. The cable has a six prong male plug with a red, brown, green,blue, white and black wire. The blue wire has a 100 uF capacitor installed next to the plug. Does anyone have information on this device? I would like to find the cable for it or a wiring diagram. I called Poweredge but they were no help at all, because it is a discontinued device. Has anyone in this forum used one of these, were the early ones like this worth using or is it just junk? Any help would be appreciated. Mike
Old Jul 23, 2004 | 11:53 PM
MLR1's Avatar
What year truck are you putting this on? I have that same style of box on my 01. If you have a fax# I can send you a copy of my instructions (I don't have a scanner so I can't e-mail). If not I can post wire codes tomorrow when I get a chance to look at the connections.
Old Jul 24, 2004 | 09:30 AM
Mike Lyons's Avatar
MLR1,
Thanks for the reply. We have a lot of dodge trucks go through here and I just need to know what year the power edge is for. You may FAX me at 405-624-0114.
I assume the STD on the controller means standard trans.
Old Jul 25, 2004 | 12:26 AM
MLR1's Avatar
I didn't get a chance to look at mine today. I will be working on the truck tomorrow and I will post then. I will fax a copy of the instructions on Monday when I go back to work. I am not sure on the part # year thing. I will also look at that as well.
Max
Old Jul 26, 2004 | 12:23 AM
MLR1's Avatar
The chip is for a 99, the STD is for standard program if it says HOT it has the upgrade program. My MAP sensor plug configuration is different than the 99, but I will fax that info as well. I will also send a plug detail and with that you should be able to figure it out. Look for the fax in the AM.
Max
turbo59pwr
Dec 20, 2003 07:05 AM
Jack Thorpe
May 7, 2003 11:11 AM
