Plate now full forward!!Wheeewwee!
Old Apr 3, 2004 | 03:05 PM
DZLPWR's Avatar
Talking Plate now full forward!!Wheeewwee!
I finnaly got around to sliding my plate today and man what a difference!!! I think it helped that i aready have some type of aftermarket plate (Banks?) It was in the stock position, and i put it all the way forward along with the AFC. Had to do some low boost smoke adjustments but over all it like it alot. I have only seen 950 EGT but thats only hitting 60mph for a sec. I am seeing 25-27psi, but thats what i saw before. Can i adjust my Banks waste gate or should i pinch the signal line? I also need to ID my plate. Heres some pics.
Old Apr 3, 2004 | 03:07 PM
DZLPWR's Avatar
Anybody know what profile this might be??
Old Apr 3, 2004 | 05:57 PM
joefarmer's Avatar
It looks close to the #8 plate photo I have. PM me your email address if you would like the picture.
brandon.
Old Apr 3, 2004 | 06:38 PM
Jim Fulmer's Avatar
I'm not sure what grind it is but I can tell you I wouldn't like it!
Jim
Old Apr 3, 2004 | 08:45 PM
DZLPWR's Avatar
How come? Not flat enough? I was thinking #11 or even #10, just a guess though, i havent seen either. Tonight i hit 1100 egt and i let off cause it looked like it was climbing fast. Im only getting 25 psi, but i think the WG is kicking in. How should i get more boost? Adjust the WG or disable it. If i disable it, could i over spool the turbo? Its got the 14cm housing on it. My guess is that i dont have enough boost for the top end fuel so thats why my egts are kind of high?
Old Apr 3, 2004 | 08:51 PM
BigBlue's Avatar
I wouldn't disable it. I'd adjust. That way you don't risk over spinning the turbo.
Old Apr 3, 2004 | 09:18 PM
MnTom's Avatar
I am willing to bet that you have a #8 plate in the picture. That is just like the one in my truck.
Anybody know why I don't feel that much of a differance with the plate all the way back and all the way forward?
Tom
Old Apr 3, 2004 | 09:40 PM
BPonci's Avatar
Thats a hi power Banks plate. Just took one out of a customers truck with the same number.I think that is the same plate that Fulmer uses to get 775.
Old Apr 4, 2004 | 09:42 AM
DZLPWR's Avatar
BPonci, you wouldnt happen to know what HP that customer got from the plate do ya?
#8??? Geez, i would think my egts would be more out of control since i have a 5spd 215 pump? Ive only got BHAF straight pipe in the air flow dept. I guess its enough.
MnTom, my guess is cause its an auto and you just dont get that positive pull of a manual.
Old Apr 4, 2004 | 12:53 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
The 62402 Banks plate is awful close in bottom side fueling to a #10 TST, although, like many of the Banks plates, it cuts back on high RPM fuel.
Old Apr 4, 2004 | 08:30 PM
nascar mark's Avatar
LMFBO
DZLPWR,
Not even close to a #10 profile.
Old Apr 4, 2004 | 10:03 PM
DZLPWR's Avatar
What do you mean by not being close? Less agressive than a #10 or more. Do note that i have not seen many different fuel plates. Just some pics online and the one ive got.
Old Apr 6, 2004 | 11:39 PM
travjrath's Avatar
try this cut loads of power , smoke , egt's , boost and fun
Old Apr 7, 2004 | 11:24 AM
gunracer1's Avatar
lots o torque in that profile, but i can see egts rollin quick
Old Apr 7, 2004 | 10:56 PM
travjrath's Avatar
HEHEHEHEHE REAL quick!!!!!!!!
95dodgectd
24
Feb 15, 2008 04:51 PM
TurboChris
Nov 4, 2007 01:45 PM
West Coast
Jul 4, 2007 10:25 AM
windkid4
Dec 6, 2005 10:32 PM
windkid4
Nov 29, 2005 09:20 PM
