A-pillar pods
Old Nov 19, 2005 | 01:17 PM
eric13's Avatar
A-pillar pods
I was wondering if you can get a three gauge a-pillar pod that replaces the factory one completley instead of cobbing it on to the existing factoryone. I have that setup now and I dont care for it at all. It squeaks and rattles and just looks cheap. Any suggestions?
Old Nov 19, 2005 | 03:01 PM
crobtex's Avatar
My factory a-pillar is in a box in my garage. The new 3 pod is attached by one screw at the top. It tucks under the weather stripping and looks just fine.
Old Nov 19, 2005 | 03:09 PM
eric13's Avatar
Was this a direct replacement with the clips that hold it to the pillar and if so where did you get it?
Old Nov 19, 2005 | 03:13 PM
crobtex's Avatar
NO clips. It is held in place by the shiny screw above the top gage, the dash at the bottom and the weather stripping on the edge.
Old Nov 19, 2005 | 03:17 PM
eric13's Avatar
OK thanks alot
Old Nov 19, 2005 | 05:25 PM
Big Deezul's Avatar
I did mine almost the same exact way...I used a push pin instead of a screw...just looks a little cleaner
Old Mar 16, 2006 | 07:39 AM
dl.'s Avatar
dl.
Where can I get one of those pods like you have?
Thanks
Old Mar 16, 2006 | 09:06 AM
Mechanos's Avatar
Ditto that.
My pod was actually sold as FULL A-pillar cover and was meant to cover the entire A-pillar. It came with those little christmas tree type push in fasteners to hold it to the stock A-pillar cover. I threw those away, put the stock cover in a box in storage and just used the new piece as a stand alone cover held in place exactly as mentioned above.
Old Mar 16, 2006 | 10:31 AM
Mark Craig's Avatar
eric13,
We stock the 2 and 3 gauge color matched 'Replacement" mounts for the 2003+ trucks. They are molded in the same color and even with the same material suppliers material as the stock Dodge A pillar. They fit and look stock! For the 1994-02 trucks you have to use the pillars thay lay over the stock ones. They are supplied with rachet pins to connect the two pillars, and lots of members have used double stick tape as well.
Mark @ DPPI
Old Mar 16, 2006 | 11:22 AM
kawi600's Avatar
The pods are great, I have the same triple setup on mine. They dont impair visibility any further since theyre in line with the pillar. You need to -really- be careful about adding to the profile of that pillar with those plastic rain deflectors though. I hit a pedestrian once that was crossing where she shouldnt have been, and right on the other side of that pillar. Thank god she wasnt really hurt since I was going real slow. Its a real nasty blind spot, just an FYI, Id lose the deflectors.
Old Mar 16, 2006 | 12:05 PM
Moose10's Avatar
Originally Posted by Mechanos
Ditto that.
Mine's the exact same way.....except it's held in place with a black drywall screw see gallery. I got mine from Wildcat Diesel (no longer in business). No squeeks or rattles....it looks stock...except for the screw, but it blends in really well.
gunnie
Apr 1, 2007 08:19 AM
WideOpenThrottl
13
Apr 7, 2006 01:38 AM
fiveology
Jan 2, 2006 04:23 PM
atc250r
15
Sep 15, 2005 01:39 PM
Mopar_Mudder
Nov 16, 2002 01:30 PM
