performance upgrades for towing
I'm going with the Edge Comp and injectors. Should I spring for the drag version??, only for when not towing for the extra fueling on 5x5?? What size injectors should I go with for best towing and for best performance I know I need to compromise. Would 275 or stage 1 or stage 2 or stage 3?? What about the BD-Power X or XXX. Some say stage 2 injectors( 80 hp ) will work best, some say they will be to hot when towing. Everyone agrees the stage 1 injectors won't overheat. I was looking at the BD XXX and they are rated at 90 hp. between stage 2 and stage 3. Would these work?? or should I go with the BD X rated at 50 hp. Or is there better injectors out there?? Help!!
Re:performance upgrades for towing
After talking with Scott at MassDiesel Performance, I went with the DD2's for towing. If your putting a comp and injectors on, you better look at upgrading that Auto as well! Give Scott a call, he'll steer you in the right direction, plus your not too far from him!
Tony
Tony
Nov 29, 2004 10:47 AM
HorseHauler
Nov 2, 2004 08:02 PM
d-hlaw
Nov 25, 2002 11:43 PM
