Perception or reality
I have the D25 2 inch coils with the Skyjacker upper and lower links. Is it my imagination, or is the front axle no longer centered in the wheel wells? It truly appears to be aft of centerline. If this is so, is there a correcting link kit to move the axle forward so in a lock turn, my tires don't rub the mud flaps?
Thanks
Thanks
the more you raise it, the more the wheel will move back. the control arms' radius is what brings it back. in other words, with the arms pivoting at the frame and connected to the axle, the axle will begin to swing down and back when raising the front...which is why some of the larger lift kits have a 'long arms' option,
FYI...http://cgi.ebay.com/ebaymotors/94-06...spagenameZWDVW
It's that nature of the beast. When you lift, the axle rotates down and to the rear of the truck.
Longer arms are only wise if the frame mounting point is moved aft, like the Dick Cepek 6" kit.
Otherwise, stick with stock length or close to it.
Your axle is constantly moving when you're driving. Suspensions are designed to move. Making suspension adjustments based primarily on how a truck looks motionless is unwise.
jh
jh
I don't think anything will change except the ride will be stiffer with the SJ coils. Since you already have the blocks you already pulled the axle back and the 1/2 taller the springs are wont mean much.
The ride will be stiffer? ok. I was thinking of getting dual shock mounts with 4 5100's in front. Will that be too stiff do you think? I will have a Road Armor bumper on the front, and a 12,000# winch up there this yr.
I really cant say as I haven't added any extra weight to the front of my truck other than the front hitch but I did notice the springs to be stiffer. I don't know that the 4 shocks would be necessary becase the 5100s are the most capable shock I ever ran?
