PE Comp/PE Drag
Old Feb 19, 2003 | 10:54 PM
ARAcummins's Avatar
PE Comp/PE Drag
I am curious as too what the difference is in the PE Comp and the PE Drag, or are they the same thing. I can't seem to find anywhere that has the PE Drag, on the net anyway. I have seen a few people talk about it and even a few list it as a modification. If there is a drag then where can I find one, how much, and what is the difference?<br><br>One more thing, diesel dynamics has what looks like a PE box but claim 150 rwhp, anybody know where they are getting the extra 30 horse? I called on it and they want $800 for it. <br><br>With all this talk on fueling boxes and the price for them I want to make sure I get a good one that suits me best. I don't want to spend that kind of money on and edge ez to decide a month or two later that I want the comp, like some of you guys have done and worned about. Once ya start ya can't stop right.
Old Feb 20, 2003 | 01:04 AM
Cat Cracker's Avatar
Re:PE Comp/PE Drag
Hello, and welcome. I'm sure someone will correct me if I'm wrong, but I think the difference between the regular PE Comp, and the PE Drag Comp is the fact that the regular comp defuels at 2700 rpm, and the &quot;drag&quot; version keeps fueling untill 3200 or so. I dont know if the drag version fuels more aggressively or not. I had a regular PE Comp, and it worked great. Someone else will have to advise you on the Diesel Dynamics version, as I have no expierence with those.<br><br> Cat Cracker.
Old Feb 20, 2003 | 10:43 AM
PourinDiesel's Avatar
Re:PE Comp/PE Drag
On level 5x5 the Drag Comp seems to fuel more aggressively all the way through the power band.<br>The upgrade is worth the money in my opinion.<br>If you are wanting a Drag Upgrade on a regular Edge Comp.<br>Contact Edge Products.<br><br>www.edgeproductsinc.com<br><br>--Justin<br><br>
Old Feb 20, 2003 | 11:16 AM
KennyM's Avatar
Re:PE Comp/PE Drag
I have the UFM Drag version. The power seems to come on sooner and last till 3200ish RPM. <br><br>As far as 30 more hp over the Edge, not. I dynoed 404 hp an Edge equiped truck dynoed 389. My torque was 875, Edge was 905. Both of our trucks have DD II's.<br><br>Which ever box you get, make sure you get the drag version. Well worth the few bucks.
Old Feb 20, 2003 | 03:34 PM
atoughram's Avatar
Re:PE Comp/PE Drag
[quote author=KennyM link=board=7;threadid=11180;start=0#106955 date=1045761369]
[/quote]
Looking at your sig line, I should be right in that area as far as HP is concerned... Clutch will be done @ Piers in March then off to the Dyno... What are you seeing for max EGT's? Even with the PDR turbo, I can attain 1500 at will.. dont spend much time there though - dont wanna pour my pistons out through the drain plug...
Old Feb 21, 2003 | 09:33 AM
Ramflasher's Avatar
Re:PE Comp/PE Drag
It is my understanding from lots of research that the only difference between the regular comp and drag comp is the extended fueling, beyond 2700rpms or so...<br><br>And the extended fueling is only on the 5x5 setting...all of the other settings still defuel...
Old Feb 21, 2003 | 09:50 AM
ARAcummins's Avatar
Re:PE Comp/PE Drag
[quote author=KennyM link=board=7;threadid=11180;start=0#106955 date=1045761369]<br>I have the UFM Drag version. The power seems to come on sooner and last till 3200ish RPM. <br><br>As far as 30 more hp over the Edge, not. I dynoed 404 hp an Edge equiped truck dynoed 389. My torque was 875, Edge was 905. Both of our trucks have DD II's.<br><br>Which ever box you get, make sure you get the drag version. Well worth the few bucks.<br>[/quote]<br><br>What is the UFM Drag version?
Old Feb 21, 2003 | 10:15 AM
fj40charles's Avatar
Re:PE Comp/PE Drag
[quote author=Ramflasher link=board=7;threadid=11180;start=0#107328 date=1045841595]<br>It is my understanding from lots of research that the only difference between the regular comp and drag comp is the extended fueling, beyond 2700rpms or so...<br><br>And the extended fueling is only on the 5x5 setting...all of the other settings still defuel...<br>[/quote]<br><br>This is not correct. I've talked to Aaron at Edge Products and he said that drag comp on 5x5 is different program than a standard comp box on 5x5. It fuels earlier and goes up to 3200 rpms. All other setting (levels 1-4) are the same.<br><br>Charles
Old Feb 21, 2003 | 10:17 AM
Re:PE Comp/PE Drag
[quote author=ARAcummins link=board=7;threadid=11180;start=0#107341 date=1045842608]<br>[quote author=KennyM link=board=7;threadid=11180;start=0#106955 date=1045761369]<br>I have the UFM Drag version. The power seems to come on sooner and last till 3200ish RPM. <br><br>As far as 30 more hp over the Edge, not. I dynoed 404 hp an Edge equiped truck dynoed 389. My torque was 875, Edge was 905. Both of our trucks have DD II's.<br><br>Which ever box you get, make sure you get the drag version. Well worth the few bucks.<br>[/quote]<br><br>What is the UFM Drag version?<br><br>UFM version is the Diesel dynamics box box (re-badged PE COMP box). It is supposed to have less timing advance than a standard comp box. <br>[/quote]
Old Feb 21, 2003 | 11:25 AM
KennyM's Avatar
Re:PE Comp/PE Drag
atoughram, I have not exceeded 1500. With 4.10 gears I run through the RPM's to quick. I am never in any gear for more than a few seconds when drag racing. In fifth I run out of RPM's and defeul before the traps. This might all change though, I went up two tire sizes to get me over 100MPH, that still will only leave me in 5th for about five seconds.<br><br>Also you mention clutch, My stock clutch worked fine for over five thousand miles, but I did not have the drag version yet. When I put in the SBC the stock clutch still looked new. I was and still am shocked at that.
Old Feb 21, 2003 | 02:35 PM
dodgeram's Avatar
Re:PE Comp/PE Drag
is it possible for me to send in my comp and have it reprogrammed/converted to a drag comp ......<br><br>if anybody has done this how much does it cost .......<br><br>also what's the downside to a drag comp over the regular one........
Old Feb 21, 2003 | 02:41 PM
hellotbone's Avatar
Re:PE Comp/PE Drag
dodgeram YES its about 200 bucks to have the upgrade done from a comp to a drag comp.<br><br><br>Contact Edge for more info!
joefarmer
20
Dec 11, 2004 05:25 AM
White00
Nov 19, 2004 09:18 PM
ratsun
Sep 26, 2004 11:16 AM
MoreSmoke
Jan 7, 2004 09:40 PM
hellotbone
18
May 16, 2003 04:40 PM
