P-pump tech
Old Dec 31, 2010 | 01:35 AM
dodgetrucker75's Avatar
P-pump tech
just a lingering question i have...
i am running with no plate or afc, and it takes a lot of throttle control at all times, but i love it that way, the only issue i have is getting rpm's...
the question, does stopping the rack travel with a plate, afc, ect. while pushing throttle past that point, do anything different than stopping it at that point with the throttle???
Old Dec 31, 2010 | 02:27 AM
Tate's Avatar
No.
Old Dec 31, 2010 | 02:35 AM
simple enough, thanks tate
i ordered a new gsk just about an hour ago, hopefully that will solve my issue, i started with a 3k which was awsome, then got the upgrade to converte the 3k to a 4k, and have nothing but problems, i have tried the stock settings, i have run them tight, loose and everywhere inbetween, with no luck, just wants to fall on its face around 3k and wont free rev past 3500, so hopefully an actual 4k kit will solve my issue,
Old Jan 2, 2011 | 07:24 AM
AlpineRAM's Avatar
Short question: Does it smoke when it falls on it's face?
If yes- you have too little air in the combustion chamber, but more than enough fuel.
If no- look at the pump. It might well be that you don't have enough fuel pressure to fill the pump at the high revs. (Overflow valve, lift pump), or your governor limits the amount of fuel (change gsk)
Timing is another issue.
I think you should check the points I mentioned first, because when you change stuff at the governor springs but have no effect at high revs it points towards the problem residing somewhere else.
HTH
AlpineRAM
Old Jan 3, 2011 | 10:48 AM
infidel's Avatar
Too much fuel before boost builds can put out the fire resulting in poor acceleration.
Old Jan 3, 2011 | 02:28 PM
well i'm still going to hope its missmatched gsk, i have a fuel pressure gauge, and has plenty of pressure, air is no issue, i got plenty there too, and its not over fueling because it will do the same thing if i just roll into it slowly, messing with the spring adjustment did change some littile things but the overall result was still about the same
19mike92
Jun 21, 2013 11:48 PM
huntinguy
Mar 26, 2011 02:53 PM
bc3
Feb 5, 2011 05:53 AM
Smkndzl
Jun 27, 2005 11:01 PM
rattle_rattle
Nov 18, 2002 07:49 AM
