overhead console temperature
Old Feb 1, 2010 | 07:22 AM
milesfelix's Avatar
Does anybody know specifically where the temperature probe is for the overhead console? It's been amusing watching the overhead read a consistant -40*F when it's been at least 20F above zero. I figure it's time to fix that.
Old Feb 1, 2010 | 08:38 AM
Diesel_Dan's Avatar
if you are looking at the front of the truck with the hood open it is mounted on the rad. support just to the right of the ac condensor (drivers side)
Old Feb 1, 2010 | 10:58 PM
camelracer's Avatar
The sensor on your '01 is located on the back side of the grill. A -40* reading means the sensor circuit is open. Measure the resistance to find out where it's open. The resistance should be between 336k ohms (-40F) and 2.488k ohms (131F).
Old Feb 2, 2010 | 07:34 AM
milesfelix's Avatar
That makes sense now because I've had the hood off before, and more than likely fubarred something in the wiring. I was rebuilding the engine in my dad's shop in the back where it isn't cemented so pulling the engine with a cherry picker was not an option, and thus had to pull the hood and use a loader tractor to pull it up and out. Schweet gives me something else to fix now
Old Feb 2, 2010 | 08:12 AM
larrybartlett's Avatar
there's a wire connector about 1/2 way back on the hood by your hood light, mine came uncliped, check there first
Old Feb 2, 2010 | 07:48 PM
milesfelix's Avatar
yeah I know the clip now...schweetness. should be able to see if this truck of mine will start in the next couple weeks haha
Big Mac
Sep 29, 2008 08:25 PM
gator_grabber
Mar 29, 2008 10:42 PM
moparmatt
Jan 7, 2008 07:22 AM
PurNLoud
Jul 23, 2006 05:51 PM
rico334
Jul 1, 2006 10:42 PM
