overdrive/tans temp
overdrive/tans temp
I just put a gorend triple disc in and now the trans temp light is on and it won't shift into overdrive.... is there a way to bypass it and just put adifferent on off switch for overdrive
there are three wires coming out of the harness on the trans that control the OD and lockup. the orange wire is the OD you can wire it to a switch that controlled by ground and run it that way.
jason
j2mk
Mar 11, 2008 02:02 AM
downlow
Feb 28, 2006 06:23 PM
hognutz
Nov 28, 2005 12:16 PM
