Oil/lubrication
Oil/lubrication
my friend owns a repair shop, we were talking tonight, he said the price of oil has taken a jump. he asked his distributor about the increase, and they told him the government made all the oil co's take zinc out of automotive motor oils, and that zinc was the main lubricating factor in oil. it evedently pollutes more than the feds want. my ? is what is lubricating in the oil now? i have already switched to amsoil, but i figured this would be something to be brought up here for you guys to hash out, maybe someone knows more.......
Zinc has not been outlawed in engine oil. May be coming in the future but has not happened yet!
Zinc is not the main lubricating factor in oil. It's an anti-wear additive used by higher quality oil companys in very small percentages, less than .5% by weight.
OIL is the main lubricating factor in oil!
Four functions of an engine oil = Clean, Cool, Seal, Lubricate.
Additives do the first, oil does the rest.
RJ
RJ
Originally posted by Cowhand
Hmmmm....
Maybe lubricating oil is going up because crude oil has gone up?
Hmmmm....
Might be a good time to stock up but remember the additives do fall out of motor oil in about a year. No big deal in a small container you can shake up but not so in a drum.
btw-- that Zinc is actually ZDDP-- zinc diethydiphosphate. It's an extreme pressure lubricating agent. It's held with valve stem and ring wear (other other really high-shear areas).
Justin
Justin
Justin
Just for the record, I think you will find it's Dialkyldithiophospate....if anyone cares.
My lubrication manual says it's not really an EP (chemical) protective agent...but an Antiwear (physical) protective agent.
Regarding the original question, EP additives and/or Antiwear additives do not, by definition, provide lubrication (ie; reducing frictional drag). They simply provide a buffer between metal to metal contact. They may, or may not, provide a more "slippery" surface, but this is not their purpose.
Correction to above - Zinc is used in small amounts; less than .2% by wt.
RJ
PS: Justin - Still no T-Rex in your signature...change your mind? Respect your opinions and was anxious to hear final evaluation based on your research.
RJ
gnuesse
33
Jan 26, 2006 06:57 AM
SolarRam
15
Nov 22, 2005 12:36 PM
04ctd
Jan 23, 2005 06:12 PM
DDahl
Jan 17, 2005 05:28 PM
