Noisy Boost Gauge
Should my boost gauge be noisy? I have a 60psi autometer boost gauge and it is very noisy. The truck is stock except for the K&N filter and 16.2cm exhaust housing. A couple of my firends have gauges and are not noisy. The truck is a 96 2500 Ram.
Thanks for the help |
Re:Noisy Boost Gauge
Could be that you used a very stiff tubing for connection. Did you use copper or stainless maybe??? If you use rubber, it will damper the pulsations from the intake of the engine, which is most likely what you are hearing resonating from the gauge. I bet the gauge wont like that either long term..
Zino |
I am using copper tubing. I tried using the plastic but it kept kinking. Any suggestions?
Cheap and nasty fix. Near the engine crimp the copper tube almost closed. If the gauge is still noisy crimp it some more. You may find that the pipe has to be crimped almost completely closed before the noise goes away.
FWIW -
When I installed my fuel pressure gauge (mechanical) the hose I used was covered with braided stainless steel and quite stiff. The hose seemed to carry a vibration (you could feel it by holding the braided steel covering) from the engine into the cab and you could hear it. I started out by wrapping the braided steel line with rubber hose and tying it down. Finally adding a short piece of rubber hose between the schrader valve and the braided hose cut down on vibration transmitted and the noise in the cab. It would not suprise me if your copper tubbing was carrying a vibration into your cab which could be causing a good part of the noise you are hearing. |
Stan will crushing the hose make the gauge read wrong? Im just wondering couldn't it restrict the flow to the gauge?
Mine does the same thing, espically when under hard acceleration. Gets louder as the boost increases..Has a plastic line..I'm guessing it is vibrating against other wires in the guage pod. The guage doesn't fluctuate or bounce, and its been doing it for a few months. Its a buzzing sound, correct?
yes sir the stainless line for my fuel gauge does transmit a lot of engine noise into the cab also.
A metal pipe could transmit noise into the cab. Two solutions to this problem.
1) Install a short piece of rubber hose to isolate the engine from the cab. 2) Make a coil in the pipe (near the engine) of at least two turns. Diameter of the coil not that important, but suggest 2"-3" dia. Yes Jamie, crushing the hose will restrict the flow. It is called an orifice. Crushing the pipe is a very crude way of making an oriface. Restricting the flow will not cause an erroneous reading. At the most with a really tiny orifice it wiil cause a sluggish reading. By reducing the full flow of the medium (this works for fuel pressure as well) you in simple language, restrict the pulses that can reach the gauge. Some guys install a needle valve before the fuel pressure gauge. This is just an adjustable orifice. Hope this helps to explain things. |
Heh heh. Hey Beavis, he said orifice. Heh heh. ;D
