no power to edge
Old Nov 27, 2007 | 06:01 PM
bill moore's Avatar
no power to edge
First my turbo timer function on my edge juice stopped working. Then I put a plow on my truck and the edge stopped working all together. I have checked the fuse from the battery and the one that is tapped in to the fuse near the master cylinder. I installed this thing myself but forget what each of those power supplies are for? I have checked the ground that is on the battery. Any other ideas? I am not sure why my turbo timer stopped working either not sure if the two problems are related? thanks
Old Nov 27, 2007 | 07:30 PM
haloman's Avatar
Check to make sure none of wires are chaffed or your plow wires are interfering with edge harness.
Old Nov 27, 2007 | 07:33 PM
bill moore's Avatar
Yup did all the usual stuff all the plow wires are in the front of the truck
Old Dec 3, 2007 | 06:05 PM
bill moore's Avatar
Got it working. I forgot that there was a wire going to the fuse panel on the side of the dash, it came off Somehow my turbo timer got turned off so all is well now.
Old Dec 3, 2007 | 08:23 PM
Adam3291's Avatar
I hate those push connectors that go on the fuses with the Edge kits. You got to really make sure you get them in good.
racebeeper68
0
May 27, 2008 06:34 PM
racebeeper68
May 27, 2008 06:12 PM
Hoss
13
Jun 18, 2004 06:14 PM
powerwagon440
Jan 20, 2003 08:50 PM
