Nitrous
Nitrous
Hey all i have heard that you can hookk up N2O to our diesel trucks, does anyne know what is need to do this as I have a 95% complete setup from an old car setup, the only thing I dont have is the accel. pedal switch, which I can easily buy,
I am asking basically what is needed to make this safe for the engine, I dont plan on running it all the time just when I feel like clowning,
I have a set of twins I will eventually install but my tranny wont hold up to that so i would like to use this to get more power, I have an older superchip, thatr plugs in line with the engine harness, AFE filter air box replacement, 5 inch exhaust, turbo back.
bigger intake manifold.
what do you guys suggest
also on the subject of twins what things should i do for the twins in the future, (injectors, tranny upgrades, etc. a different chip? ) thanks
as far as I can tell it works, I will research how to test, to make sure,
Thanks for the answer but I top of all of that, I am looking for info. on the actual steps, like do I have to run diesel spray along with the nitrous like in a car, and things like timing and such, sorry if this question doesn't make any sense but I can hook up the setup right now but I dont want to hurt anything by doing something dumb.
you run a dry nitrous system in diesels. cant really do a wet system unless you want 180* of timing. the great thing about diesels is you cant run them too lean (like a gas motor). the more air you have the more efficient and cooler burn you have.
yeah thats what I thought bur wanted to make sure (about running a fogger nozzle) and no fuel, I will have to find a boost type of trigger, any suggestions? also what size of a shot would you suggest on a basically stock (except some bolt ons) motor? again as I said I have a twins setup sitting on the shelf for the near future
Mike D
87
Apr 10, 2008 03:18 PM
KatDiesel
Oct 15, 2003 08:09 PM
kingofdodge7131
Dec 9, 2002 06:12 AM
