next upgrade
Old Jul 10, 2008 | 09:44 PM
dodge_diesel's Avatar
next upgrade
Currently on my truck I have exhaust, smarty, air intake, head studs,and jammers. and im about to buy a fass, What should I upgrade next? I was thinking racing twins but I know im gonna have to upgrade my tranny soon, bigger injector tubes? vp? bigger sticks? im trying to make it fast
Old Jul 10, 2008 | 09:57 PM
dieselrob's Avatar
Get them gauges on there asap. Then i would do the trans. Its the best mod i ever did to my autos. Then form there you can put a tst comp on there and turbo and have one heck of a truck.
Old Jul 10, 2008 | 10:40 PM
forgot to say I have gauges, whay about twins? I know there expensive but is there a single that can add some hp? (alot)
Old Jul 12, 2008 | 01:20 PM
oaborbag's Avatar
first you need to decide how much hp approx. you are wanting before you decide on a turbo, you can get a big single that will produce similar power to twins for cheaper, BUT your egt's will most likely be higher, and the spool time will be a lot slower thus the advantage of having twin turbo's, if you are not worried too much about a little slower spool, there are a lot of big turbos out there making huge power numbers, the silver bullet is one of them and there is plenty more.
Old Jul 12, 2008 | 01:39 PM
Big Blue24's Avatar
With a 2wd, you will probably have traction issues as you continue to up the power. Especially with a built automatic, it really puts the power down. Most guys that occasionally drag race their 2wd are running big single turbos. The single's spool slower allowing you to get rolling before the big power hit that will cause you to spin.
Old Jul 12, 2008 | 07:26 PM
luke@ddp's Avatar
Do the trans first all the power in the world is useless if you cant get it to the ground.
blackdevil
Jan 2, 2006 09:57 PM
greyrig05
Jul 17, 2005 07:13 PM
2500CTD
May 23, 2005 08:12 AM
CODODGE2500MAN
Jan 11, 2005 03:51 PM
boiler-rat
Dec 31, 2004 10:16 PM
