Next mod to fix EGT issues
Old Feb 17, 2008 | 06:00 PM
heykw's Avatar
dont feel bad I thought the same thing
Old Feb 17, 2008 | 07:14 PM
HOHN's Avatar
Originally Posted by marine4life
the pre ignition usually happens in the older 12v's because of their static timing, usually not an issue with the VP variable timing. As long as you set the methanol to inject at the right time, you will get a nice added power boost and a drop in EGT's with no problems.
Meth preignition has nothing to do with injection timing. It has to do with cylinder temps and compression ratio. The meth preignition occurs when the meth lights off before there's any fuel even injected.
jh
Old Feb 17, 2008 | 07:34 PM
marine4life's Avatar
jh
Ok, Im a little confused then. Doesn't injection timing directly correlate to both cylinder temp and compression ratio. The more the advanced the timing, the higher the cylinder temp and pressure, this would be why water methanol would be better suited to variable timing vice static.
Old Feb 17, 2008 | 09:21 PM
heykw's Avatar
Is anyone running Nitrous?
Old Feb 17, 2008 | 09:29 PM
No laughing gas for me, yet. Not until I oring and stud. Im not even sure if it would be smart for me to run NOS with the Water/Methanol kit, even after studs and oring. Maybe one of the diesel guru's will chime in with some wisdom.
Old Feb 17, 2008 | 10:03 PM
Tate's Avatar
Originally Posted by smokeum99ta
You have got to be kidding me, i've been looking at turbo's for awhile now and was only gonna do a single but with the price of $2,434.50 I mise well step up to twins. Probably need a $1000 or more of stuff to add to that price to be complete, but if not I might take the jump.
Add $1k of extras, and you have the price for the full kit. Thats one of the better prices on the BD twins I've seen. I almost bought those actually, but apparently, they weren't expensive enough for me.
Indeed, injection timing does increase cylinder pressure and temps, but so does intake temps and pressure. If you double the intake temps and pressure, you're gonna have a lot more temperature and pressure after you've compressed it tenfold. You may already have surpassed the flash point of the meth, which will cause it to ignite. Still haven't had the fuel injected yet, but you already have ignition.
Old Feb 18, 2008 | 12:11 AM
Big Blue24's Avatar
Nitrous would help, but not with your currently welded shut wastegate. It would just overspeed your already oversped turbo to the point of explosion. A standard s300g is not gonna keep all of your fuel in normal egts. You are setup just like me, only you have a smaller turbo. You would help out your heat and up your power a bit if you had a functional wastegate. Welding it shut with that small 9cm exhaust housing is a tight choke point for your motor.
Nitrous will most definitely lift your head and blow the headgasket in your situation without some head studs and orings.
You could help out your situation some by buying a used HX 35 with a functional wastegate, but it is not gonna fix the problem.
You really need a HTT 62/71/13-14, some head studs. Or the twins would work nicely with your currently fueling as well.
Old Feb 18, 2008 | 12:13 AM
Big Blue24's Avatar
If you just want to win in the mud drags, air down those tires and lock up both differentials. You probably can't use more that 400 HP in the mud anyway, unless you run some paddle tires!
Old Feb 18, 2008 | 08:48 AM
somis13's Avatar
is it true an intercooler from BD or spearco will lower the e.g.t. by like 150*? I read that in the new diesel power magazine. and was considering one
Old Feb 18, 2008 | 09:09 AM
heykw's Avatar
It is called the mud drags but it is more like a tractor pull type course it is really red clay and yes I did air down my tires
Old Feb 18, 2008 | 11:44 AM
Big Blue24's Avatar
I recall some "dirt" drags in California where Maddog with his 1000HP+ was getting smoked by 700 HP trucks cause he couldn't get the power to the ground.
You say clay, well then you were ok for traction. But seriously you need a turbo! One of those ATS Aurora 3000's might do the trick. 1215 bucks on ATS's website. Probably 1400 with shipping and downpipe. Ohamaram did 648 HP on the dyno with his CR, so it should cool down your 500 HP worth of fuel. If you want to spend the money, twins would give you faster spoolup and more top end lungs egt wise than any large single turbo out there.
Old Feb 18, 2008 | 08:43 PM
heykw's Avatar
I would like to get twins but I am on a tight budget about 3K or so
Old Feb 18, 2008 | 08:57 PM
displacedtexan's Avatar
Can you weld?
Old Feb 18, 2008 | 10:29 PM
heykw's Avatar
yes I have a mig.
Old Feb 18, 2008 | 10:32 PM
I prob could have put this with the question but Rip at www.sourceautomotive.biz could hook you up with the stuff to do twins for around $3k, I'd talk to him.
