New Stainless Pipe Header!
Old Apr 22, 2009 | 11:20 AM
  #46
Mopar_Man's Avatar
Ok a cuple more questions. 1 Can you flip it to run compounds? 2 Have you or anyone tested it on a truck in the 4-500 HP range vs the stock manifold or any of the other cast manifolds out? Im verry interested in one & need to do something. TIA Oh and also my EGT port is 1/4" NPT can that be taken care of buy you guys?
Old Apr 22, 2009 | 11:30 AM
  #47
Patriot1's Avatar
The only real problem i have with it is that my exhaust has to get all redone in my truck. My turbo is in the back of my exhaust manifold.I have the industrial version with the allison trans and it looks like it moves the turbo to the center of the manifold. I would have to get it and look and see if my floor needs to be either trimmed off or a rise in my floor.Does anyone live in NC so i can come look at it and take some measurments and go from there?
Old Apr 22, 2009 | 11:50 AM
  #48
Mopar_Man's Avatar
Originally Posted by Joseph Filippi
I've ran this now for a couple days and it provides an astonishing amount of better air flow, very very noticeable. Now I'm headed towards turbo upgrading and 3000 GSK.
Can you tell us what you noticed? Faster spool up, lower EGT's, More power ect... Please fill is in a little bit. Thanks.
Old Apr 22, 2009 | 11:53 AM
  #49
dstad's Avatar
yea all the doge cummins 12valves have a mid mounted turbo. you could just go out and get an old mainfold and use that as a measuring divice.
Old Apr 22, 2009 | 02:59 PM
  #50
Swarthy Dago's Avatar
1. better air flow, my turbo is blocked but I saw better boost, which in turn put more fuel in so now I have to back off on the plate. The spool up was about the same for a hx35, still launches great, and pulling hills I have probably about 100 deg F. cooler exh. I see more smoke but its when the torq conv locks up so i have to use my foot more to control it, such as don't let it lock up untill the rpm is up (keep your foot into it, let up a bit when it locks up, then get in to it slowly again. Any suggestioins before I start tuning ? Plate or starwheel ?
Old Apr 22, 2009 | 03:01 PM
  #51
If someone is thinking of flipping this manifold over it isn't going to work. The header holes don't line up properly, correctly installed it goes right on no problem at all. It doesn't seem to get too hot either. Better than the stock one acting like a heat sink.
Old Apr 22, 2009 | 03:32 PM
  #52
Mopar_Man's Avatar
So you got better performance?
Old Apr 22, 2009 | 06:55 PM
  #53
to me yes, better air flow = better performance
Old Apr 23, 2009 | 11:14 AM
  #54
Mopar_Man's Avatar
I thought in the birst post or so he said it could be fliped? So if it can could you use it for twins. If you can im about ready to buy
Thanks.
Old Apr 23, 2009 | 11:22 AM
  #55
to flip it over just chop off the flange turn it over and reweld, would take 10 or 15 minutes.
Old Apr 23, 2009 | 11:40 AM
  #56
Mopar_Man's Avatar
Is this thing strong enuff to support compound turbos? & what did you see when you put this manifold on? faster spool & lower EGT's? How about top end performance?
Old Apr 23, 2009 | 11:42 AM
  #57
Mopar_Man's Avatar
Oops im sorry I didnt realize your the same person i asked that to befor.
Old Apr 23, 2009 | 11:51 AM
  #58
Mopar_Man's Avatar
& was there any fitment problims or did it bolt right up like it should? Sorry for all the questions. Just want to get everything straight befor i fork out this kind of money for an exhaust manifold.
Old Apr 23, 2009 | 10:01 PM
  #59
Hello MM
The fitment was superb ! If one wanted to support twins with it I would have to say they would need to add one more mount to be safe. I realized better performance. I'll explain a little because I also went to a 3GSKit. I realized more boost via what I believe was due to more rpm from more air flow. I also ended up with more smoke so I turned down fuel via the star wheel. Now I have less power through out the whole power range. The spool up was a little better, now its gone down. The engine still launches but not so much now that I turned down the fuel. What I need now is more air, a diff. turbo. That will yield the air to burn more fuel. If I'm correct more boost also enables more fuel in itself without doing anything regarding fuel settings, I saw more smoke. The GSK really didn't give me more rpm and that is something that puzzles me. Now I need suggestions for a turbo upgrade. I tow and race around town. Any suggestions ?
Joe
Old Apr 24, 2009 | 11:17 AM
  #60
Mopar_Man's Avatar
Hello MM
Joe
Thanks for the info. For a turbo Im all about the Ball Baring turbos. I am extreamly happy with my Garrett. They do cost a bit more but IMHO its worth it for the faster spoolup.
