New pump is losing prime
Old Jan 27, 2008 | 07:04 PM
jamesp4962's Avatar
Just installed a blue chip pump a couple months ago and have no problems unless I dial my chip up and get kinda nasty with it. Everything seems to be running fine and it's just dead. Now when I turn the chip up it gets up and goes but probably lvl 3 and up it almost feels like it has a "miss" to it. Get out and crack a couple injector lines and crank it over a few time and it lights right up. My low fuel pressure warning never goes off and i've never seen the pressure go below 7 psi. I have a high flow lift pump installed and oversized injectors as well but I never ever experienced this problem before I replaced the injection pump. I'm kinda at a loss unless I'm sucking air somewhere or there's something wrong internally with my new pump.
Old Jan 27, 2008 | 07:25 PM
IntakeRacing's Avatar
i had the same problem. long time cranking for it to start.
i put a check valve right before my fuel filter. problem solved.
rebal
Jul 1, 2007 08:28 PM
efbeason
Jan 28, 2007 08:35 PM
cmckinney
43
Mar 16, 2006 04:13 PM
GearHd6
Nov 4, 2005 06:51 PM
cummins2
13
Jan 21, 2005 04:56 PM
