New guy with timing box question
Old Aug 31, 2007 | 10:09 AM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
Hi, this is my first post so I am mostly saying hello, but I do have a question:
I have a 99 3/4 ton 5 spd that is stock except for an FMS box and 5" straight exhaust.
What is a good (and inexpensive) timing box that I can stack with the FMS? I am not looking for the most power ever, just a decent timing box that will help me out a little more. Thanks a bunch, -Evan
Old Sep 2, 2007 | 08:27 PM
anybody? whats a good timing box to stack with fms?
Old Sep 2, 2007 | 08:44 PM
rockjeep73's Avatar
edge EZ is what I run with my TST, works great for me.
part time pulle's Avatar
box
If you want a timing box without a lot of power , then I would say your best bet is a Edge EZ. Its only 65-70 HP. Alot of people stack this with a redline for the timing.. Thats what I was going to do but could not find one for a 02.. Check on EBAY they go for 150-250 bucks
Old Sep 2, 2007 | 09:35 PM
CarcajouCummins's Avatar
A power Puck is a very good stack with a FMS.
Old Sep 2, 2007 | 09:59 PM
HOHN's Avatar
I'd try the new Quadzilla XZT+-- that's probably the best boox for "stacking" out there, with all the customizability and such...
Not too expensive, either.
JMO
Old Sep 2, 2007 | 10:12 PM
kxhonda's Avatar
I am stacking my PowerPuck with my TST comp and it does well, it def makes a difference. I am thinking about trying something to give me more lowend "hit" tho. I heard the Van Aaken has more low end, but I'm really wanting to give the Quad XZT+ a try, it sounds real promising with the updatable programs.
Old Sep 10, 2007 | 06:04 PM
thanks a bunch for the replies guys. I was not aware that the XZT+ was a timing box. I will have to check that out. I am looking for more low end too. thanks, -Evan
Old Sep 10, 2007 | 07:18 PM
swmnkdinthervr's Avatar
If you order one make sure you get the XZT+ because the earlier XZT (notice the missing +) is a fueling box...
Old Sep 10, 2007 | 07:25 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Well the XZT+ is both a timing and a fuel box. It comes with a three way switch. Posistion 1) is off. Posistion 2) economy mode or timing only AND posistion 3) is a kick in the pants, being timing and fuel.
Yeah it pulls from the bottem real hard. They also have several different tunes so you can find a perfect match for your truck.
BTW, the XZT+ can only be stacked with a fuel only box that taps the VP-44 wire. There are several guys here on DTR that are having excellent results stacking the XZT+ with Banks Ottomind (which of course is a fuel only box).
Old Sep 10, 2007 | 07:41 PM
HOHN's Avatar
It's not "fuel" in the sense of this thread.
The distinction is whether it taps the pump solenoid wire.
Fueling= wire tap
Timing= no wire tap
Old Sep 10, 2007 | 07:46 PM
JPR Ram's Avatar
ah, yeah...it's still fueling. It's not wire tapping for fuel. On switch 3 the XZT+ adjustes timing and adds fuel for the power gains. It's kinda like how HRVP-44s add more fuel. But to get big fuel, you gotta bump up the voltage to the VP via tapping the wire.................
I believe...................
Old Sep 11, 2007 | 08:05 AM
thanks for the info. does the XZT+ tap the wire? I'm not following..... I understand the difference, but I'm not sure what the XZT+ does. If i stack it with the FMS, will i ony be able to use position #1 and #2? thanks everyone, -Evan
Old Sep 11, 2007 | 01:49 PM
JPR Ram's Avatar
No, the XZT+ does not tap the wire.
Old Sep 11, 2007 | 03:51 PM
Sunir's Avatar
So if the XZT+ does not tap the wire, and Smarty does not tap the wire then you could NOT stack them correct? I know XZT+ is timing + Fuel and so is Smarty. I was wondering if you could choose a 'no timing' level on Smarty and stack that with the timing + Fuel mode on the XZT+?
