Need Help Asap!!!!!!!!! No Boost!!!!!!!
if your parked the truck isn't supposed to make any boost, and they never do. if it starts and idles there may not be a problem at all take it for a drive so there is a real load on it. then go from there.
i did take it for a ride. there was no boost and the turbo wouldn't even go.
u couldn't hear a sound from the turbo. we have the air cleaner off today and we can see the turbo spin and wine. but there is still no boost. the wastegate rod doesn't even move at all either.
joe
anyone?????
joe
anyone?????
ok i just took the truck for a spin. there was no boost and no power at all. the exhaust temp went all the way to 1,200 when i floored it. as soon as i let off it went down to around 600.
how can we check to see if the acuator is working or not. maybe i got a bad one directly from banks. idk. but something is makeing me not get any boost or even spool the turbo up.
it starts up and idles fine.
just no turbo action or boost.
joe
joe
how much play should be in the turbine on the air inlet side?? it spins freely but u can move it up and down about 1/4 inch. could this be the problem??????
the turbo worked fine until we put this kit on last night and now we are having all these problems.
thanks
thanks
Update: according to Holset, the spec for radial play is 0.012" - 0.018" and axial play is 0.001" - 0.005".
there is no in / out play at all. there is only up and down play and it doesn't seem to be hitting the housing at all when its spun while holding it up or down. there is some resistance but its not from hitting the housing. it doesn't feel that way anyway.
GMAN07
WERE ARE U LOCATED HERE IN IOWA?????????
thanks,
joe
GMAN07
thanks,
joe
I'm in Clinton County, in Eastern Iowa.
So the turbo spins freely, wheel doesn't touch the housing, spins at idle but won't spool when driving?
Where are you at in Iowa? I'd be happy to help if it isn't too far.
Take the actuator rod off and wire it shut....if you still have no boost the problem does not lie in the actuator. You say you have a pac-brake in your sig....is it working correctly? A large enough boost leak will prevent you from making boost but usually you will just make alot less and slower. With a boost leak you will still hear the turbo spooling. I would wire the actuator shut and if there is still no boost or noise of spooling i would take another look at the turbine housing, making sure you didn't bend any fins and everything is installed properly.
