Need 50 horse's
Old Aug 8, 2005 | 05:04 PM
downlow's Avatar
Need 50 horse's
Lookin to get at least 50 hp whats the best and safest upgrades. I already have 4" exhaust but other than that its a stocker and kdp fixed. Probably should install pyro eh...
96 2500 4x4 reg. Cab
Old Aug 8, 2005 | 05:15 PM
Rattlerattle's Avatar
Guages then a #10 plate.
Old Aug 8, 2005 | 09:21 PM
bmoeller's Avatar
Yep, a #10. Slide it ahead a little from stock. Adjust the boost elbow so you won't go over 30# boost.
Old Aug 8, 2005 | 11:28 PM
yfz450guy's Avatar
what is a #10 plate?
i am new to the ways of the cummins. this is my first one.
Old Aug 9, 2005 | 06:18 AM
SHARPMACHINE's Avatar
A #10 plate is a torque plate. Plates are used in 12 valve engines from 94-98. You will catch all of this stuff if you keep reading and looking around. BHAF = big honkin air filter.
You will want to start with a box or injectors.
welcome aboard
Old Aug 9, 2005 | 06:37 AM
Rrloren's Avatar
You could install an after market air intake to go along with your 4" exhaust then slide the fuel plate forward , should get you more H P.
Old Aug 9, 2005 | 01:34 PM
RowJ's Avatar
Plate selection here... http://www.tstproducts.com/
Old Aug 9, 2005 | 02:25 PM
mkubacak's Avatar
What box for a correctly valved engine? I thought boxes were available for us over-vavled folk.
In terms of injectors, you can do a whole lot of stuff before you start looking a 370 injectors or even aftermarket injectors.
Old Aug 9, 2005 | 04:21 PM
TxDiesel007's Avatar
boxes are for 24V trucks
fifty more horses or so is easily achievable... A good set of gauges is a must, next get a 10 fuel plate, and a GSK 3K for good distribution, set the plate farther up than stock position, and an air intake.. Is ur tranny manual or auto?
Tx
Welcome to DTR, make sure and put ur ride in ur sig...
Old Aug 9, 2005 | 04:35 PM
govspringbounce's Avatar
Re: Need 50 horse's
If it's a 5 speed, you can slide your fuel plate all the way forward, disconnect & plug the line to the wastegate & you're there. Freebie.
Old Aug 9, 2005 | 07:38 PM
bmoeller's Avatar
This chart is better than the TST chart.
Old Aug 10, 2005 | 02:47 PM
wcbcruzer's Avatar
Just wondering... Did you guys notice a drop in MPG after sliding the fuel plate forward and increasing boost?
Old Aug 10, 2005 | 04:55 PM
not at all
my mileage at worst stayed hte same.. with the extra fuel for hte low end that is needed to get the rig moving, u actually use a lil less pedal pressure, so ur savin fuel (probly mililiters, but at pump prices who complains?). this is just my experience talkin, plus read around, ull see guys with more fuel and mods tend to get a lil bit better mileage due to the trucks bein real monsters at certain throttle positions..
Tx
Old Aug 10, 2005 | 05:32 PM
wcbcruzer's Avatar
Hmm... With that said, then I'm doing it.
Old Aug 17, 2005 | 04:59 PM
downlow's Avatar
Thanks fellas
Got back from Canada whew what a drive ehh(lol)..Gonna get that #10 and install air filter along with pyro-. Thanks for the lead in the right direction.
CapnRam
Jan 4, 2010 12:46 PM
1985cucv
May 18, 2009 08:35 PM
s cesnick
Jan 2, 2008 10:53 AM
PChouinard
Jul 26, 2007 10:32 AM
