Mystery switch question...
Old May 11, 2005 | 05:23 PM
I SPEED's Avatar
Looking to wire up a Mystery Switch. Where can I find the wire color and location for the TC lock up wire?
Any help greatly appreciated.
Old May 11, 2005 | 06:09 PM
cumminsdriver635's Avatar
Here you go. Just follow the right set of instructions for your year model, and you should have no problems. Its easy as heck to do; and sure is fun to use.lol Here is the link:
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Good luck
Eric
Old May 11, 2005 | 07:44 PM
I SPEED's Avatar
Thanks Eric, that's what I was looking for.
Anyone seen the schematic for wiring up the switch using 3 relays? This one uses a safety by using the brake switch as a shut off.
Old May 11, 2005 | 08:04 PM
Mcmopar's Avatar
I have copies of that, if nobody else helps you out e-mail me and I will send them to you-I am out of town until Monday morning.
Old May 11, 2005 | 10:06 PM
2k1yzfr1's Avatar
Does it make a big difference in your 0-60 times or does it just feel like it?
Old May 12, 2005 | 12:02 AM
DustyRock's Avatar
Infidel has it in his gallery. SWITCH
Old May 12, 2005 | 09:51 AM
I SPEED's Avatar
According to the wiring schematic for the PCM there are 2 orange/black wires. How would you go about testing them to find the T/C lock up wire?
Old May 12, 2005 | 02:39 PM
chasd60's Avatar
The center plug on the PCM has the wire you are looking for. Orange wire/black stripe.
Old May 12, 2005 | 02:50 PM
The lockup switch made almost a 1 second difference in my 1/8th mile times! Thats quite a bit.
Eric
Old May 12, 2005 | 02:57 PM
67HotRod's Avatar
I have the mystery switch on my truck and just started using it. Besides turning it off before stopping any pre-cautions? Wondering if shifting while locked is a good idea?
Old May 12, 2005 | 10:48 PM
2k1yzfr1's Avatar
So say if I got beat by a truck length before would I be able to be that same truck again with the mystery switch?
Old May 13, 2005 | 03:45 PM
SuperDave4x4's Avatar
So whats the mystery switch all about? I read the installs, but dont really know how or when to use it. Is it something that you can just use when you want to?
Old May 13, 2005 | 05:35 PM
mr T's Avatar
the switch lets u lock up the TC in 3rd and 4th ...ans stays locked unless u hit the switch again...with valve body mods i think u can lock in 2nd 3rd and 4th....in my opinion unless u have high line pressures i would avoid the switch unless u can be cautious with it (not many can)
u know that feeling when ur just soft footing it through town and u hit 3rd gear but ur speed is still pretty low and then u get the lock up and it drops u to 1200rpms and the poor lil truck shakes a bit?! well thats not a good thing that switch will cause that pretty often...just my 2 cents
Old May 13, 2005 | 08:39 PM
I SPEED's Avatar
McMopar please disregard the PM I sent you.
I installed the switch today and went to the track tonight.
WOOHOO!!! what a difference this makes...6/10's shaved of my 1/4 ET and 3 MPH. If someone had told me this little switch could do this I would not have believed them.
I've got it wired using 3 relays being able to use the brake (as well as the switch) to disengage the T/C when coming to a stop.
Old May 14, 2005 | 04:41 PM
If its like my truck the answer would be yes. It makes a world of difference with mine. You would at least be able to run right with them then.
NOSPIN4ME: What did you turn through the 1/4 mile. I went to the 1/4 last night and turned a 16.23@81mph as my best time. Im pretty happy with how the truck is running.
Eric
