Mark Kendrick Compounds
Old Mar 5, 2003 | 08:02 AM
  #31
70crewcab's Avatar
Re:Mark Kendrick Compounds
Gene, you should feel a HY30-9cm on the bottom end ;D The top end is a little choked. I swapped out Craigs HY30 for an HX35 to help in the 4000+ rpm range he likes to rev to.<br><br>'laggy' is a relative term. They all have lag the question is how much is acceptable.<br><br>A properly wastegated small exhaust housing IS better. I run an HX35 on top just like you but using the gate I can adjust the effective size of the exhaust housing to yield max boost of around 40psi to over 80psi(way over )<br><br>This gives me the same top end flow characteristics as your setup .. sort of, my engine is not limited to the flow of a single exhaust housing.... with spoolup better than most stock turbo trucks.<br><br>Craig's exhaust side was not restrictive but the intake side was. the compressor on the HX30 was just not big enough for top end power. For towing and daily driving it was unmatched. His ~650hp daily driver can be driven with NO SMOKE and still light the tires on shifts... I drove it.. AMAZING!!!<br><br>I have to admit that a most of the credit for Craig's truck must go to him and ATS for building an engine that lets my turbos shine. Then to ATS and SouthBend for putting it to the ground.<br><br>Craig, how are those new stacks????? ;D<br><br>we need pics!!!!!!!!!<br><br><br><br>
Old Mar 5, 2003 | 01:08 PM
  #32
Cmonroe's Avatar
When it stops snowing I'll get some pictures and post them. They have been the topic of conversation for days now here in the Denver area. To correct you however it was a hy-30 9 sq I was running before, for daily driving and towing it can not be beat.
Old Mar 5, 2003 | 01:15 PM
  #33
Sled Puller's Avatar
Sort of is right! Big cam, she flows real well at 4000rpm+ ;D<br><br>Uh-oh, 650hp from the west again?<br>Does he plan to race anywhere this year?<br><br>Some 500hp trucks pretty much crushed a west coast 650 hp truck at Muncie last year, I think the dynos are off out there. :P :'(
Old Mar 5, 2003 | 01:32 PM
  #34
Cmonroe's Avatar
Sled Puller you can talk to me directly if you want to. Maybe we should do a heads up at May Madness. Sled Puller you run a 5sp right. What is your fastest time? Maybe this could be fun.
Old Mar 5, 2003 | 02:28 PM
  #35
TxDieselKid's Avatar
Sled Poke race? What a joke! <br><br>Maybe if he would step up, and get some real injectors, other then those 370's. :P
Old Mar 5, 2003 | 03:30 PM
  #36
TDK, <br>I have already committed to the heads up class at Muncie, 2 weeks ago.<br>Those 370s will do just fine.
Old Mar 5, 2003 | 03:35 PM
  #37
[quote author=Sled Puller link=board=7;threadid=11097;start=30#112045 date=1046899806]<br>TDK, <br>I have already committed to the heads up class at Muncie, 2 weeks ago.<br>Those 370s will do just fine. <br>[/quote]<br><br>Your going to race? Is this April 1st? Rememebr you got to make it through the Pulling without any problems to race. <br><br>I think your right, those 370's should do just fine, as paper weights.
Old Mar 5, 2003 | 03:54 PM
  #38
If I tear up the puller, I'll run the hauler, Sunday. <br><br>It's stock.<br><br>I believe I'll only need one mod to whip you with it, Andrew.<br> <br>Change it over to Amsoil.... yep that should be sufficent to pound the pinko faggy Texan. :-X :P : [undecided]
Old Mar 5, 2003 | 05:18 PM
  #39
[quote author=Sled Puller link=board=7;threadid=11097;start=30#112053 date=1046901250]<br>Change it over to Amsoil.... yep that should be sufficent to pound the pinko faggy Texan. :-X :P : [undecided]<br>[/quote]<br><br>Ok, your stock puller rig, against my truck at Muncie, want to put some money on it? :-*
Old Mar 5, 2003 | 06:02 PM
  #40
70crewcab's Avatar
So... we're urinating for distance now??????
Old Mar 5, 2003 | 08:59 PM
  #41
Like you do anything different Mark? Why havn't you raced David's little Ford yet? <br><br><br><br>I love you uncle Mark. ;D
Old Mar 6, 2003 | 07:42 AM
  #42
70crewcab's Avatar
Bring it to May Madness. My truck'll be in true form by then. I'm tweakin it a lil' :P
Old Mar 6, 2003 | 09:50 AM
  #43
Cmonroe's Avatar
Bring them all to May Madness, my truck is always ready to race.
Old Mar 6, 2003 | 10:08 AM
  #44
70crewcab's Avatar
[quote author=Cmonroe link=board=7;threadid=11097;start=30#112367 date=1046965844]<br>Bring them all to May Madness, my truck is always ready to race. <br>[/quote]<br><br>and he's got pretty new stacks too
Old Mar 6, 2003 | 12:14 PM
  #45
StakeMan's Avatar
The low rpm response of Cmonroe's truck is impressive. There should be several 500+ trucks from the west at Muncie this year.
