making it pour out
Old Mar 28, 2005 | 02:52 PM
mitch@jc'sCTD's Avatar
making it pour out
I dont want to start a war about pollution but how can I get my truck to smoke like crazy for little or no money (ppreferrable none at all) is there any other ppump mods that can be done? See my sig to check out my very limited mods
Old Mar 28, 2005 | 06:32 PM
caleb c.'s Avatar
From the little that I know that is about it for the pump,right?It isn't smoking as it is?Slap a set of 370's on it and lay it down.Or disable the turbo,won't run to good but I bet it would smoke!
Old Mar 28, 2005 | 07:42 PM
Forrest Nearing's Avatar
grind the plate flat... don't grind it too deep or you'll blow through the converter and tranny, but just grind it flat even with the deepest point on the plate... then open up the AFC housing and remove the spring... it'll fog pretty good when you lay into it down low
Forrest
Old Mar 28, 2005 | 07:58 PM
boostedte37's Avatar
Forrest
Does anyone have pics on this grinding procedure
Old Mar 29, 2005 | 01:53 PM
What does it take to grind the plate down?
Old Mar 29, 2005 | 02:23 PM
HOHN's Avatar
I'm guessing a grinder
Old Mar 29, 2005 | 02:48 PM
that's what I used!
Old Mar 29, 2005 | 02:56 PM
shoe's Avatar
you want smoke buy a TRAIN!
Old Mar 29, 2005 | 03:06 PM
CTD NUT's Avatar
Take your plate out and remove the AFC spring like Forrest said.......that should make it smoke nice and heavy.....should mess some things up and run like s@#* but you will have your smoke for free!
Old Mar 29, 2005 | 03:10 PM
don't take the plate out... grind it flat and remove the spring... it'll run great...
removing the spring on my truck was just too much... it would bog the motor down when you laid into it... but with your fueling, it'll be fine IMHO
Old Mar 29, 2005 | 03:21 PM
HappyGA's Avatar
edit
Old Mar 29, 2005 | 09:03 PM
Dieseldude4x4's Avatar
You mean pour out like this?
https://www.dieseltruckresource.com/...php/photo/3800
Old Mar 30, 2005 | 11:49 AM
CTD NUT's Avatar
I was just kidding around about taking the plate out but if all you want is lots of smoke with minimal effort, then removing the plate is easiest......personally, I only think smoke is cool when the truck is making big power.....I think it is very uncool to make a CTD smoke for the sake of seeing black smoke spewing into the sky.
Old Mar 30, 2005 | 11:55 AM
well, at his fueling levels, a flat plate and removed AFC spring isn't going to put out so much fuel that it'll bog the truck down, but it'll light that turbo up pretty quick!
Forrest
Old Mar 30, 2005 | 07:24 PM
mkrenn's Avatar
Do it right. Go buy a plate. I BIG plate. I had a 96, and got a (what they called the biggest) 300 HP plate from Blue chip Diesel. YEAH baby! It smoked! But, ,, got a lot of EGT, so be carefull! Most of all,,,, have fun!
