LP's...Holley Red, Blue, Black...???
Old Jun 22, 2004 | 10:22 PM
gsdog1's Avatar
Your lift pump is toast!
Matt
Old Jun 23, 2004 | 03:20 AM
BigBlue's Avatar
It could be days, months, years before it dies. Who knows. I would definately get it a statement from dodge saying that if it dies within X amount of time, they cover it under warranty. Dodge knows the problem with these pumps. Don't let them screw you over.
Old Jun 23, 2004 | 05:40 AM
DaNuGuy's Avatar
Do you think the pressure I am seeing is a result of the IP pulling the fuel through? When I bumped the starter and left the key on, I had 0 pressure. I would think that if the LP was doing anything it would show up then also.
Any one have any thoughts on the Summit brand fuel pump...140 gph, 18 psi?
Thanks for all the help yous guys.
Old Jun 23, 2004 | 02:36 PM
Erik88GT's Avatar
That should be just as good, if not better than the Holley blue. It even looks like it might be a relabeled Holley black?
Some of you have the colors confused. Holley blue is 14 psi, red is 7psi.
Moroso also sells a spring to get more pressure out of the Holley blue.
Old Jun 23, 2004 | 03:31 PM
AlpineRAM's Avatar
My holley blue went up to 30 psi in stock form. had to tweak the spring to get it to 16 (Idle) and 14 (WOT)
AlpineRAM
Old Jul 10, 2004 | 11:43 PM
J Double's Avatar
Hey guys, how much "tweaking" are we talking about when stretching the spring.....1/8", 1/4" 1/2"? I'm ready to put the Blue in tomorrow, just wanted to verify on stretch. Thanks.
JJ
Old Jul 11, 2004 | 07:59 PM
J Double's Avatar
Well I got the Blue in today but unfortunatly I don't have my steering column mount for my Dakota Digital gauge so I hooked up a spare boost gauge I had lying around just to get an idea on pressure. At idle I'm getting 12-13psi, I don't have a long enough hose to run into the cab so no WOT numbers yet. The truck does seem to pull alot harder and smoother but I'd like to get the pressure up a smidge.....any suggestions on the spring stretch? I would tinker with it but where I have it mounted (stock location) it's a real PITA to get to the screw so I'd like to do it once and be done with it.
Old Jul 11, 2004 | 09:57 PM
gsdog1's Avatar
I would talk with Ryan about the tweak.
Also just curious, why did you mount in the stock location? Seeing as you are from AK, I may know the answer!
Matt
Old Jul 11, 2004 | 10:31 PM
J Double's Avatar
Matt
Your right, trying to keep it warm and clean, although from the looks of the stock LP I not to sure how clean it'll stay. Also, Rod at Wildcat said it would be just fine in the stock location in conjuction with the Max Flow kit.
Southern Pride
Mar 2, 2010 10:23 PM
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
Rammandan
Jan 28, 2007 11:00 PM
dieselbeef
May 4, 2006 08:04 AM
