Lower EGT's
Old Sep 20, 2004 | 03:58 PM
Mcmopar's Avatar
Lower EGT's
I modified my Dad's 96 4X4 Dually with 4.10:1 ratioand the auto with an AFE, number 6 plate, and an AFC spring kit. While trailering his boat which weighs 17,500 on the trailer the EGT's will get to 1,500 Degrees on a long hill. Is there anyway to lower the Temps without moving the plate(less Power)??
Old Sep 20, 2004 | 05:19 PM
More boost. You should get a TurboMaster or at least a boost elbow and get the boost cranked up to 30 - 35 psi. Should cool things down a lot.
Old Sep 20, 2004 | 10:19 PM
BigBlue's Avatar
An exhaust will help some to.
Old Sep 21, 2004 | 08:11 AM
Mcmopar's Avatar
Sorry, not enough info was given by me, the truck has a 4" turbo back and a turbo master with 38 psi on the boost gauge under load.
Old Sep 21, 2004 | 08:15 AM
Eskimo's Avatar
Get a Scotty II
Old Sep 21, 2004 | 08:57 AM
Mcmopar's Avatar
So you think the Scotty II is going to lower temps much more than the AFE???
Old Sep 21, 2004 | 09:35 AM
Rattletrap1's Avatar
Can always ease back on the go pedal. Might be able to play with timing.
That's one huge boat to be trailerable...
Old Sep 21, 2004 | 09:44 AM
Mcmopar's Avatar
When towing, it keeps you on your toes. Pulling back on the pedal will help cool things off, but I would like to be able to avoid that. This truck is a HOSS, she doesn't slow down no matter how big of a hill-70MPH!!!
Old Sep 21, 2004 | 11:21 AM
infidel's Avatar
Definitely. I've installed several AFE's for folks who have complained it did nothing for their egts. Not one complaint with the Scotty, most report a 150° decrease in egts under load. The Scotty sucks cool outside air while the AFE sucks hot underhood. Big difference.
Old Sep 21, 2004 | 11:24 AM
Mcmopar's Avatar
Do you have to drill the cowl hole or not?
Old Sep 21, 2004 | 12:11 PM
infidel's Avatar
To reap the full advantages you should drill the hole
Old Sep 21, 2004 | 09:35 PM
justinp20012500's Avatar
Ok guys no one has said it... Get twins!!! HX40/35 with a HT3B. Long periods of time (more then 1 min) at 1500 degrees will cause huge problems. I would go with the afe, more filter surface. I would aslo bump the timing to around 15.5 degrees.
If you are only hitting 1500 with a load that big I think the truck is doing very well!!!
Old Sep 22, 2004 | 08:41 AM
Mcmopar's Avatar
Twins or just a bigger single?
Old Sep 22, 2004 | 09:11 AM
BigBlue's Avatar
I'd just do a bigger single. Either a hybrid 35/40 or a PDR HX40. One of your egt problems is your pushing your turbo to hard. The hx35 is only good up to ~35 psi. After that, it goes way off it's efficiency map.
Old Sep 22, 2004 | 09:49 AM
Mcmopar's Avatar
What's the price diff in the hydrid and the HX-40? Best place to buy from you guys that have??
