Low boost?
Low boost?
Firstly, more of a curiosity question than a problem question. The truck I am talking about is in my sig. The Most boost I have ever seen is 26lbs and that was running empty. With the edge on stock I see 20-22lbs and every level after that it maxes around 24-25 and 26 one time. I tow quite often and I stay at or below 1150 degrees pulling 10-12k on hills at 5000ft of elevation so it's not like I have a cooling problem as of yet. I'm just curious as to why I only see what I'm seeing when others on this forum and others run 30-35lbs on their hx-35 with similar mods. I have the boost elbow from edge installed and even clamping off the line between it and the wastegate does nothing. All connections between turbo and intake manifold are tight. No high boost codes either. Is there something I am missing or am I perfectly fine? Thanks in advance!
Moobesor
Feb 23, 2008 09:57 AM
