Looking for a 3 - 5
Old Jul 30, 2004 | 03:15 PM
12valve@heart's Avatar
Looking for a 3 - 5
Can anyone recommend a good source for a 3"-5" exhaust adaptor? I'm coming out of my 3" decelerator exhaust brake and want to run 5" the rest of the way but don't want to do a 3-4 and then a 4-5 like the local truck shop suggests. I know they must be out there but haven't found them yet.
Thanks in advance
Old Jul 30, 2004 | 03:40 PM
Zino's Avatar
Unless you are planning on future mods, 3" inch all the way is all you will need. Furthermore, 3" to 4" then 4" to 5" is a better way to do it if you insist. From a piping standpoint it might seem Rube Goldberg, but from a physics and fluid dynamics perspective it transitions the flow much better.
Zino
Old Jul 30, 2004 | 08:39 PM
Well, as far as future mods, the 16cm turbo housing is sitting on the bench as is the exhaust brake and the HD valve springs are on order. I just happen to have a 4' length of semi stack that I was planning to put behind the exhaust brake and have it turn down and out in front of the rear tire, thus the need for the 3"-5". Once I get the exhaust system redone, my plan is to up the pump timing a bit and then look into injectors if necessary. The current goal is somewhere around 250hp.
F1B3R
Jan 2, 2011 08:59 PM
89dieselkong
Feb 12, 2010 12:47 AM
theIntlEggrole
Jul 16, 2007 05:53 PM
bob95065
39
May 7, 2007 09:48 PM
