locking wastegate?????
Old Sep 1, 2005 | 04:45 PM
Lrdchaos's Avatar
What have you guys used to lock your wastegate closed on you turbos? I want a cheap way of doing it. so plz tell exactly what parts it takes to complete the j hook.
Old Sep 1, 2005 | 09:18 PM
Gotlift01's Avatar
I used a turnbuckle that you can find at any local hardware store. I don't know if you know what the are or not, but I will explain anyway just incase someone else doesn't.
The turnbuckle has 2 hooks facing opposite directions from each other and thread into a rectangular piece of metal. One hook as a right handed thread and the other has a left handed thread. So when you turn the center piece of the turnbuckle it will tighten up.
The one that I used was a 7/32" thread and was 4" to 6" in length. You take one end and hook it on the back of the wastegate acctuator and the other on a lip on the bottom of the turbo right above the wastegate acctuator head. You might have to do a little bending of the hooks to get it to hook good.
Also watch out after you put it on, they tend to vibrate loose and fall off!! You can also get a longer turnbuckle and hook it onto your fitting on top of your oil filter ( lot less chance of it vibrating loose ) plus you can actually get your hands on the dang thing to really tighten it down. It doesn't pull hard enough to worry about bending your oil line so I wouldn't worry about that.
I did another version involving a spring so that I could adjust my boost instead of completely locking it shut...................I have some pics in my gallery if you want to take a peek?
The turnbuckle itself cost like $3.00 if that!!!
Old Sep 1, 2005 | 09:29 PM
Gotlift01's Avatar
Click on this link, this shows a perfect example of what I'm talking about!!!
https://www.dieseltruckresource.com/...ght=turnbuckle
Old Sep 1, 2005 | 10:14 PM
Rods's Avatar
u want cheap just take out the brass insert for the wastegate in yr compressor housing and buy a 1/8 in pipe plug and yr done now considering yr mods u can overboost easy i c 30 lbs with a 60 hp box but lets say u have injs and such and u c 40 and u want 30 or 35 just drill a small hole in the plug to let some bleed off , i used a ZERK fitting i had laying around hopfuly somebody wont shoot grease in it
sallyman1
Feb 10, 2008 06:17 PM
ataboy9026
Feb 22, 2006 05:09 AM
xp8103
Dec 25, 2005 09:45 AM
MoparRiggan
Oct 13, 2005 11:54 AM
TPilaske
Mar 3, 2003 06:04 AM
