Little more tweaking(turbo/fuel sys.?)
OK, 6 - 8 months ago I was satisfied with my trucks performance. (Running consistant mid to high 14 sec 1/4 mi) EGT's running a little high but the stock turbo spools up pretty fast with 35+ boost pressure. My stock fueling system is running 8 - 10 WOT and 14 psi idle.
I'm thinking about getting Dodgezilla turbo and Fass system.Would anyone have suggestion/experience? Would these additions add much to my performance? Also I see there are more than one choice when it comes to the Fass system. Would there be any improvement by using the most expensive?
Thanks for any suggestions in advance!
Gene007
WarWagon
Gene007
WarWagon
If you have the slightest doubt in your mind that your gonna want more, go ahead and get the HX 40 from either Piers or JR Adkins (I think he does a 40). If not, then the Dodgezilla turbo will work great with your current setup. The FASS is always a good thing to have.
TNutcher
Aug 7, 2009 11:53 PM
2500CTD
May 23, 2005 08:12 AM
suttonbeeman
15
Nov 6, 2004 08:52 AM
Palmetto_kid
Nov 10, 2003 11:22 AM
