KORE Suspension Kit for 03 Installed on 99
Old May 5, 2008 | 01:53 PM
Dalydrvr's Avatar
Anyone ever installed the KORE HP series kit for the 2003-2008 on their 99 diesel? How did it work? They say it will fit but the front end may be higher than the back? Is the ride on the street any better then stock??
Old May 5, 2008 | 02:07 PM
ellerman's Avatar
It will fit but the KORE drop blocks for the sway bar aren't the best option because you will bend the links from your sway bar to your axle. I would go with a starter kit from Carli or Thuren. Eric
www.thecarlisuspension.com
www.thurenfabrication.com
Old May 5, 2008 | 03:18 PM
Dalydrvr's Avatar
Thanks for the help. Do any of these kits really improve the street ride or are they mainly designed for high speed off roading? I'm thinking maybe for my mostly on-road use and slow speed off-roading these kits would be a waste of money. True?
Old May 5, 2008 | 04:37 PM
XLR8R's Avatar
Of course they'll really shine in high-speed offroading, and their street benefit is subjective... ask 5 guys and you may get 7 opinions.
You probably don't need them, but how could you not want them?
If you do lift it, a sector shaft stabilizer with integral drop blocks for the sway bar will maintain the endlinks' OEM geometry.
Old May 5, 2008 | 10:14 PM
kennyblatz's Avatar
i have only put in the front end of my carli starter kit but there is a major improvment in street ride not to mention offroad, thuren didnt seem to have anything close to a starter kit (all high end offroad) as he told me to go with the carli stuff
Old May 6, 2008 | 02:29 PM
Dalydrvr's Avatar
I have also looked at Carli. Is the ride stiffer than stock on the street? Your front end must be higher than the back right now huh? If I may ask where did you get it?
Booboo
Dec 10, 2008 08:02 PM
trik396
Aug 4, 2006 01:58 PM
Viperdew
Jul 21, 2006 07:02 PM
EricK
Apr 15, 2005 04:34 PM
Scott_W
Apr 4, 2005 01:31 PM
