jammer nozzles and injectors?
Old Aug 28, 2008 | 03:54 PM
sthrnrider's Avatar
what is the difference between these 2? i was looking at them and was curious thanks for your help
Old Aug 28, 2008 | 04:40 PM
CMooreBLKSMK's Avatar
The nozzles are just the tips of the injector and you put them on your injector body.
The injectors, well thats just it, the whole injector.
Cory
Old Aug 28, 2008 | 04:55 PM
sthrnrider's Avatar
thanks would it make a difference to just put on the nozzels?
Old Aug 28, 2008 | 05:00 PM
hamilton71801's Avatar
I went with just nozzles and am happy. At first I had a lopey idle but after some miles and installing the XZT+, it went away. To prevent the lopey idle you probably need to get them pop tested once you put the nozzles on your body or you could just buy some already done and slap'em in. My injectors had @150K when I did the upgrade and still haven't had to get them pop tested.
Old Aug 28, 2008 | 05:18 PM
AggieJustin's Avatar
The difference is that if you buy the full injector, you just pull your current injectors and swap the new ones in.
If you just get nozzles, you'll need another set of injectors to install the nozzles onto, or you'll have to pull your current injectors and replace all the nozzles before re-installing. And if you do nozzles, it's a good idea to have them calibrated to make sure they are all opening in the same pressure range.
xOmertAx
20
Feb 17, 2007 09:52 PM
storx
Jul 11, 2005 07:20 AM
OldSmokey
Feb 22, 2005 11:39 AM
OldSmokey
Feb 11, 2005 08:29 PM
Ocmechanx
Jan 14, 2005 10:10 AM
