installed j hook
installed j hook
installed a j hook but didnt do much did it per instruction also tried to move waste gate with a pair of pliers wont budge does it loosen up when it gets hot
Originally Posted by bluedodge3500
installed a j hook.... tried to move waste gate with a pair of pliers wont budge does it loosen up when it gets hot
30 psi sounds about right for a J-Hook with a comp box & stock injectors! It's also all you want with your stock HY-35 turbo.
RJ
on 5x5 it takes a little bit to build 30 psi at wot it will go right to 28 then try to climb the needle bounces some back and fourth too
Tommy93w350
27
Apr 1, 2009 01:39 AM
rjm022
Nov 23, 2006 11:29 AM
Dodgezilla
Mar 12, 2003 01:50 PM
tomsauto
Nov 18, 2002 07:22 PM
admin
27
Nov 12, 2002 04:47 PM
