Injector coper washer thickness ?
Old Mar 28, 2026 | 01:35 AM
oldblues's Avatar
Question Injector coper washer thickness ?
HI ,
how does one know what thickness copper washer to install on the injector to head seat ?
looks like my stock ones were .060
saw they make diff thickness ones why ?
thank you !
Old Mar 29, 2026 | 09:42 AM
nonrev's Avatar
10 Year Member
The thickness of those washers affects the spray pattern in the bowl of the piston, thicker washers it will be wider when it hits the bowl and thinner will concentrate the spray into the center of the bowl. If the truck is all stock never had the head off or shaved, I would stay with the stock thickness. I would say that someone more knowledgeable about this will chime in soon but not so sure of that anymore. I have read that you can heat those copper washers up to glowing then let them cool and they will work like new.
This is what google says about it.
To anneal copper washers, heat them with a torch (propane, MAP gas, or a stove) until they reach a dull cherry-red glow, which softens the metal. Immediately quench the hot washer in water to remove heat scale and create a soft, pliable washer that provides a perfect seal.
Mclair
Apr 3, 2010 11:30 AM
93Fury
Feb 3, 2009 05:53 PM
Jason_K
Jan 13, 2009 10:48 PM
berner
14
Feb 4, 2006 05:58 PM
Captain Insane-O
Feb 20, 2004 12:39 PM
