Is an HX35W turbo an upgrade for a 91 NON- I/C
Is an HX35W turbo an upgrade over a stock 91 NON- I/C??
the 91 has an 18.5cm now??
Just curious because I have a chance to pick up on one pretty cheap off a 95 CTD, thanx, DAVE
Yes it would be an upgrade, there would be some tricks to hook it up. The HX-35 has a flange on the compressor outlet, thats going to make it a little tricky to hook up to the crossover pipe. Also the turbo down pipe has to be moved back about an inch because of the wastegated housing.
If this if the stock turbo off a 95 it should be a WH1C which is equivilent to a HX35, but is constructed alittle differently.
but if you just looking to spool her up quicker. just change the 18.5cm exhaust hausing to a 16 or 14 and your off and running.
with the hx you also get to remove the scilencer ring
If your handy with tools get the hx35 ,it will light up fast and it will make the truck fun to drive I installed a 16 and there is little diff. from stock + your egts will be better with the HX
you will need to move the down pipe back 1 1/4 " and build a cross over if you look at my pictures you will see a home made cross over
good luck
good luck
Originally Posted by jiMMyCTD
the effeciency range of teh hx is higher psi than your stock.
stillsmokin
0
Aug 20, 2013 06:32 PM
Haulin_in_Dixie
Apr 18, 2004 10:45 AM
