HX35W Compressor size
Old Oct 22, 2007 | 12:51 AM
MTNRAM's Avatar
Question HX35W Compressor size
Anyone know what size the compressor is on a HX35W turbo? I know the turbine housing is 12. Thanks
Old Oct 22, 2007 | 12:54 AM
Tate's Avatar
54mm I believe, although I think the 12v trucks had a larger one, around 57 or 58mm.
Old Oct 22, 2007 | 02:13 AM
lgp9999's Avatar
Yes, the 24v are slightly smaller. You can identify them by the compressor mounted wastegate actuator.
Old Oct 22, 2007 | 03:44 AM
GFB's Avatar
GFB
Is there a noticeable performance difference between the two compressors?
Old Oct 22, 2007 | 12:03 PM
PapeCAT's Avatar
the 1998.5 24V compressor is a 54 and the base is a little bit smaller. It was made to flow just as much but spool up faster with less rotational weight to clear up the low end a little bit faster.
Old Oct 22, 2007 | 01:37 PM
Muddin_dude06's Avatar
What is the exducer size on an HX35 compressor?
Old Oct 22, 2007 | 03:44 PM
HOHN's Avatar
That's what *I* want to know, too--
HX35 compressor exducer size anyone? Beuhler?
Old Oct 22, 2007 | 04:11 PM
Well I just thought about it, I have a destroyed HX35 in my garage lol. I'll go see if I can figure it out...
OK on the HX35 I just measured I couldn't find the wheel (I think it was in several pieces) but the center section's groove was 2.832" that accepts the wheel. So the exducer I geuss would be around 71mm right?
Old Oct 22, 2007 | 05:47 PM
HOHN's Avatar
Sounds about right to me...
Old Oct 22, 2007 | 05:52 PM
Hohn, I wonder how a GT4082 would compare to a stocker in flow and spoolup with a .68 a/r turbine housing?
If a minute or two I will go measure the same groove on an HX40 I have here as well... For comparison sake...
The same groove on the HX40 I have is 3.020" if that helps anyone...
Old Oct 22, 2007 | 07:01 PM
mopar-or-no-car's Avatar
I thought the hx35 had a 58mm compressor wheel and the hy35 had the 54mm compressor wheel. I just had my hy35 rebuilt and it had a 54mm wheel in it and they put a 58mm wheel in it
Old Oct 22, 2007 | 09:05 PM
HOHN's Avatar
I'm not impressed by the 4082's map at all. It's capable of higher PRs, but it's SO NARROW that's it's essentially useless imo. At a PR of 3:1, it's only 20lb/min wide! This is a very special application turbo, and I doubt that CTD is that application where this would work.
Spoolup would be OK, but drivepressure with the tight housing would be high.
I think all around the 4082 with a .68 housing would be a miserable turbo setup. Far better to drop down to the 3782 imo, or even a 3582. The 3582 will spool yesterday, buyt you'd need an adapter for the open T3 (undivided) "foot." The 3582 is a smallish turbo too, but should spool really fast-- basically the .82 housing spools 17% faster than the GT37 stg 1. You're talking about essentially a "zero lag" setup with the 3582. It's unfortunately a little too small to be worthwhile unless you are building twins in the 400hp range and want to use it as the secondary.
I've looked up a lot about the Garretts, and I think that it's best to stick with the "packaged" ones for our trucks: the stg1, 2, or 3--unless you are planning on building larger twins for sledpulling or racing, and will use a T4 manifold.
JMO
Old Oct 22, 2007 | 10:20 PM
Tate's Avatar
Wouldn't that be the same kind of flange as the HY35 then?
J OOPS
Jan 8, 2010 08:34 AM
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
JKM
Mar 8, 2006 03:23 AM
