How much power do you make?
Old May 4, 2003 | 09:32 AM
1320's Avatar
Im curious, either estimated or dyno proven. Then of course the mods.<br><br>example.<br><br>power = 400/800<br>smoke= negligible/soso/ moderate/ look out<br>drivabilty= poor, good, couldn t be much better at all<br>weight you pull= <br><br>If you had it to do over again, would you just shoot higher instead of build up slowly and keep changing parts....<br><br>
Old May 4, 2003 | 12:48 PM
Got Smoke?'s Avatar
Re:How much power do you make?
I would like to say I'd hopefully be making between 375-400RWHP with my #10 all the way forward, but try finding a diesel capable dyno in Nashville! : :P &gt;<br><br>I dunno what mine actually makes though, but it does smoke like a freight train with the rack stop removed! <br><br>Nice tailgater-deflector device! 8)
Old May 4, 2003 | 05:28 PM
drawson's Avatar
Dyno'd 532.9 HP in April
Looks at Sig for mods. It smokes but not as bad as it once did with Piers new turbo. Now it is just a haze after 10 PSI.
Had to relearn how to drive it after the newest turbo. With this new PDR HX-50 if you are into the throttle to far it is really surgy once boost come on. With all this power tire life is bad but I wouldn't give anyup for just tires. I love the way my truck runs ;D 8) ;D ;D
Engine is stock except for 60 lb valve springs. Head has never been off 148K and run strong.
My TT is about 6800 lbs. And for short hauls a back hoe and trailer @ 11800lbs.
I started with just the 230 HP plate from TST and have moved to the HP that I am at now slowly. I have had alot of fun along the way and have learned alot. I wouldn't change the way I went.
Old May 4, 2003 | 06:10 PM
Jim Fulmer's Avatar
600+ ;D
Old May 4, 2003 | 08:36 PM
Don M's Avatar
DTR Advertiser
My RAMS cohones have not dropped yet. He must be about 200HP :'( <br><br>Don~<br><br>
Old May 4, 2003 | 08:52 PM
MnTom's Avatar
From everything that I have read I should be at about 230+ HP. Most of the equipment was on the truck when I bought it. My driveability has never been better. My pyro is at only 500* at 1800 rpm on level ground. I don't see much above 800* from 0-60 mph if I keep the boost under 8 psi.
Old May 4, 2003 | 11:21 PM
dodgeman01's Avatar
390hp was my dyno without a fuel plate. 350 all the way forward with a #10 plate.<br>Drives great. I love it.<br>DM01
Old May 5, 2003 | 11:32 AM
yrusoslow2's Avatar
I would hope that I have 350+ with the things that I have done. I also started with just a TST number 6 plate and the addiction started there. I have learned a ton about these trucks since I started. My truck runs great but I still want some more power, but so does everyone else. Smokes pretty good untill the turbo catches up. I don't pull to much weight, just the occasional boat now and then but when I do it pulls great.
Old May 5, 2003 | 01:36 PM
Cummnzpowr's Avatar
405/950 was mine this last weekend...waiting for modified turbo still and a few more things :P..not bad for an auto/160 pump eh? ;D
Old May 5, 2003 | 03:39 PM
dodgeman01's Avatar
[quote author=yrusoslow2 link=board=16;threadid=14339;start=0#135066 date=1052152352]<br>I would hope that I have 350+ with the things that I have done. I also started with just a TST number 6 plate and the addiction started there. I have learned a ton about these trucks since I started. My truck runs great but I still want some more power, but so does everyone else. Smokes pretty good untill the turbo catches up. I don't pull to much weight, just the occasional boat now and then but when I do it pulls great.<br>[/quote]<br>I think you would have a lot more than that. 350 I got with just 300injectors and a cam plate modified. Nothing stays stock at my house. not even Fuel plates <br>DM01
Old May 6, 2003 | 05:25 AM
yrusoslow2's Avatar
Dodgeman01,<br><br>I hope so too but I was not sure. I read a lot on here about people who have close to the same set up as me but I am never sure. I don't have the TST plate in there any more. I ground on my stock plate so that I could slide it as far forward as possible and still be able to get the top back on. I was told that doing this was close to a zero plate but I am not sure. What kind of power do you think I am making. I can't wait to get my 4k kit. Thanks
Old May 6, 2003 | 06:50 PM
gunracer1's Avatar
359 hp,869 tq at the last dyno day. i am fixing to blow up the stock hx35, i can get 45psi way to easy. the smoke is not to bad unless i stomp it below 1500 rpm. i need to just break down and put on a set of twins and a 0 plate. i have towed at 22k gross without any problems. but i do keep a eye on the pyro. i have enough fuel to melt it down. i need more air. mike
Old May 6, 2003 | 07:37 PM
nevrenufhp's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742<br><br>There you go! a good start on twins 8)
Old May 8, 2003 | 09:59 AM
rharveysr's Avatar
Not Enought!!!! :'( :'( :'( :'(<br><br><br>Rick
Old May 8, 2003 | 08:07 PM
John_P's Avatar
My best dyno so far was at Scheid Diesel in August<br>2001 on #2 diesel only: 508 H.P./1372 Torque.<br>This was on their Mustang Inertia Load Dynamometer.<br><br>Smoke: On mine, it is LOOK OUT!! <br>Driveability: Excellent<br><br>--------<br>John_P
