How Much Boost is too much?
Old Oct 25, 2003 | 06:29 PM
Cumminsdieselboy's Avatar
Muted User
How much boost can you get out of a stock turbo before it blows up? We had our stock turbo up to 38psi today hauling 8 ton of coal. Also does anyone know if there is a difference between the Bully Dog HX-40 and the PDR HX-40. Thanks
Old Oct 25, 2003 | 06:33 PM
Watch This's Avatar
Re:How Much Boost is too much?
iv always heard a stock hx 35 wont flow enough air to damage itsself...with the stock 12 housing ive been up to 55 lbs before and its held together :
Old Oct 25, 2003 | 06:46 PM
Rebel's Avatar
An HX35 gets out of its map with much over 35 psi. Over 35 psi the discharge temp at the comperssor is to hot to gain any advantage, also the drive pressure start to get to high. An HX35 can take more abuse than most turbos but sooner or latter it's going to grenade itself.
Old Oct 25, 2003 | 06:55 PM
Muted User
hey thanks. does anybody know about the turbos in my first post?
Old Oct 25, 2003 | 08:24 PM
smittybuilt's Avatar
i don't know about the bullydog 40 but the piers 40 is the bomb!!! if you know what i mean
Old Oct 25, 2003 | 08:29 PM
Muted User
I read on Bully dog site that there turbos are rated for 50 psi
Old Oct 26, 2003 | 08:44 AM
kevinn's Avatar
When a turbo grenades what usually happens. Do pieces come off into the air intake of the engine. I just put a turnbuckle on mine and now am getting close to 30psi without a load so I want to make sure that I don't destroy anything.
Old Oct 26, 2003 | 09:59 PM
Rebel's Avatar
If a turbo fails in a big way, one of the wheels can shear off from the shaft and try to find its own way out. This usually only happens under EXTREME levels of fueling and the addition of NO2. Most commonly it is the tubine wheel that seperates from the shaft. In most turbos the turbine wheel is friction welded to the shaft.
The more common failure is the bearing section (also known as the "cartridge&quot failing due to an overboost (overboost = overspeed) or out of balance condition. The slang that seems to have been adopted for this type of failure is "huffed"
I have had the distinct displeasure of "huffing" 2 HX40's and in both cases the turbo(s) were completely ruined due to the bearing failure that let both the hot and cold wheels come in contact with their respective housings. The cartridge was also rendered completely useless.
Old Oct 26, 2003 | 10:53 PM
Tartarus's Avatar
I've read that HX40's come apart because the turbine blades are too large & heavy for hub. Blades are thrown, and the imbalance destroys the bearing first, and then the shaft. HX35's don't have this problem because the hubs are the same as the 40, but the turbine blades are smaller. That's why 40/35 hybrids are a lot more durable than 40's, supposedly.
Old Oct 27, 2003 | 07:36 AM
kevinn's Avatar
Great, thanks for the information!!!!
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
rkelley
19
Jan 11, 2007 10:59 PM
MDMIKE
Jan 18, 2005 10:02 PM
NeedMoPower
Jul 12, 2004 10:04 AM
Wes C
Dec 24, 2002 12:28 AM
