How much boost?
How much boost?
Good morning all,
I just installed my new boost gauge yesterday, and after letting her warm up I nailed it from a stop. Max boost was 24psi. Turned O/D off, nailed it again, and 24psi. Tried it on a hill from a dead stop. Broke tires loose and rear end went side to side, still only 24psi. I drilled and tapped the air horn, ran line through grommet and up to "A" pillar, no kinks or binds. All intercooler boots are tight, saw no cracks or splits. I thought with my mild mods I would still see 30-35psi boost. Any suggestions would be greatly appreciated!
That sounds to me like 24 psi is where your waste gate is set at. Did you install a boost elbow? That would allow you to build more boost. Seems like your engine is happy with the boost though. Do you get a lot of smoke at full boost? If not, I would leave it alone for now.
Tom
Tom
Tom,
I can see no smoke from a get go, nor at WOT. I would like some smoke, but can see none in the mirror. I used the boost elbow that came with the box, but I bought it secondhand. Maybe I should try another elbow.
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
