How to Install Stacks in the Bed?
Old Mar 21, 2006 | 03:03 PM
Big Smoky's Avatar
This is my first time installing stacks and wanted to know how most of yall bolted them down in the bed, basicly how yall installed them. What my plans are is to cut a hole in the bottom of the bed and run flex pipe from where I cut the exhaust off underneath the truck into the bed and somehow bolt the Y pipe to the bottom of the bed, I'm guessing and put a 45 cut on the stacks and bolt the stacks to the bed. Sound good? Any suggestions and pictures are greatly appreciated. Thanks in advance.
Eric
Old Mar 21, 2006 | 03:48 PM
blackdiesel's Avatar
Registered
this is how i did mine
thats a peice of 4x6x1/4 steel boxed on both ends and the stacks welded into it
i know this isnt waht your looking for, but if you havent already bought the round pipe, this is cheaper
Old Mar 21, 2006 | 04:13 PM
Willy91's Avatar
Thats a nice looking setup, I might do mine like that in the future.
Old Mar 21, 2006 | 04:39 PM
rockjeep73's Avatar
Sorry not the clearest picture, but mine are bolted at each stack to the front bed rail via a tab that is welded to each stack. The splitter pipe is also bolted to the floor of the bed through a tab that is welded to it.
Old Mar 21, 2006 | 05:35 PM
Buckshotmckee's Avatar
I bought the Grand Rock kit. I got pics in my gallery. The GR kit has a bracket/clamp that mounts to the corner of each pocket/rail, and the center clamp mounts through the bed (2 bolt holes).
Old Mar 21, 2006 | 07:16 PM
slim51015's Avatar
I used the u bolt clamps bolting them to a u channel and bolting the channel to the bed.
Old Mar 21, 2006 | 09:29 PM
BigBlue's Avatar
Hey eric, when I get back from austin on thursday I'll give ya a hollar and you can take a look at how mine are done.
Old Mar 22, 2006 | 12:52 AM
Big Smoky's Avatar
Sounds good to me. Thanks
Old Mar 25, 2006 | 03:16 PM
Czapla44's Avatar
just wondering
Can anyone tell me how and where i could find stack kits or do i just buy the exhaust parts....and how long do i need the stacks to be
Old Mar 25, 2006 | 03:20 PM
BigBlue's Avatar
Go on ebay and do a search for 5"x36" Miter Cut Stacks. That's how I found mine.
Old Mar 25, 2006 | 03:21 PM
Czapla44's Avatar
is that all i need is 36 inch
Old Mar 25, 2006 | 03:25 PM
BigBlue's Avatar
Yup. They'll come to just an inch or so above the cab.
Old Mar 25, 2006 | 03:28 PM
Czapla44's Avatar
when i run the pipe down the bed do i need to put heat shield on it cause i have a fuel tank in the bed
Old Mar 25, 2006 | 06:54 PM
wheelo90's Avatar
Hey Blackdiesel02,
That is the exact same set up I was thinking of doing with my truck. I found that it was rather expensive to run the Y- pipe design so I thought about building a box and fill it with smoke, with two holes coming out of the top for the stacks. Me has got a few questions for ya,
Do you get smoke from both stacks at the same time?
Does it make the exhaust setup any quieter?
Thanks for your Help and the picture,
Wheelo
Old Mar 26, 2006 | 10:19 PM
doodah's Avatar
Heres a couple pix of my own setup I built. I have since built a couple more of these and sold them locally, very good flowable design! it has complete even flow out of both stacks, due to a fliped peice of angle iron welded inside the tubing overtop of where the exhaust enters the tube, and then the angled ends of the tube!, any more Qs just ask. I do have more pix of the whole setup somewheres, just gotta find them
