How are the frames in these rigs?
Old Nov 22, 2009 | 12:23 AM
wcbcruzer's Avatar
Anyone hear about broken or bent frames on these trucks? Such as from off-roading? How strong did Dodge make them? Just curious.
Old Nov 22, 2009 | 01:45 PM
Krob's Avatar
I am really curious about this too. Anyone....
Old Nov 22, 2009 | 02:46 PM
rage_blue's Avatar
I've seen axils bent, but never seen a bent frame. But I'm a mechanic so I probably wouldn't see a truck that had the frame bent.
Old Nov 22, 2009 | 08:58 PM
Clunk's Avatar
It's a welded, boxed frame...pretty stout but heavy.
Old Nov 22, 2009 | 09:33 PM
wcbcruzer's Avatar
That's good. We're the opposite of ricers... The heavier the better! lol..
Old Nov 22, 2009 | 11:41 PM
blk96's Avatar
the frame an my 97 had cracks along the bottom of the c- channel where it goes from being boxed to channel i did not find it till i got it home and drove it for almost a month but its fixed and holding fine now with no trouble.
the guy i bought it from lived on a rough dirt road and towed a goose neck travel trailer which i think over time caused the cracks. they werent bad and werent hard to fix just sucked at the time.
Old Nov 23, 2009 | 12:30 AM
wcbcruzer's Avatar
How do you go about fixing something like that, especially if there are a lot of cracks? Unless you looked, would you have noticed them?
Old Nov 23, 2009 | 01:19 AM
wcbcruzer's Avatar
Anyone ever hear about welding extra plates to Dodge (or any brand truck) frames for added strength because they're too weak?
http://www.thedieselstop.com/forums/...rength-220245/
image courtesy of speedrcr78
Old Nov 23, 2009 | 09:12 AM
BigErksG2's Avatar
looks like a scared cat!
Old Nov 23, 2009 | 01:01 PM
Tow-mater01's Avatar
a buddy of mine has a 97 12v 13" of lift on 37's and hes pretty hard on his truck.... offroading and stuff like that hes cracked or broken his frame several times... theres all kinds of plates welded on under his truck lol
Old Nov 23, 2009 | 04:25 PM
lovinCTD59's Avatar
I have personally never seen any bent or cracked. But im sure it happens.. I have seen them cracked on a few semis tho...
Old Nov 23, 2009 | 11:59 PM
rebal's Avatar
that will happen to any pick up Ford Dodge Chevy with a slide in wrecker overloaded I have seen all 3 bent. over load anything and it will bend.
3rd gen frames are strong
http://www.youtube.com/watch?v=LKUWv8MjwJY&NR=1
Old Nov 25, 2009 | 09:14 PM
rage_blue's Avatar
I've Seen some ugly repairs on frames. The problem with a lot of guys in the oil feild is they think they can drive 140kph on gravel roads that have two foot holes in them lol. I think if you bend a frame you did something you shouldn't have, It may have a tractor engine in it, but its not a tractor!! lol
Old Dec 2, 2009 | 11:44 PM
catnfool's Avatar
I have helped weld a 97 dually reg cab; broken in half right at the cab. It was a ranch pickup with a round bale handler on it, and they would load 2 round bales on it and rattle down the gravel road!! NOTHING holds up to that for long!
Old Dec 2, 2009 | 11:53 PM
yfz450guy's Avatar
i see bent frames all the time. and i fix alot of them too.
