How effective is Nitrous?
Old Oct 12, 2008 | 06:38 PM
12valve's Avatar
Just came back for some street racing, i ran the 98, My friend ran his 99 Dodge, its got a 66 Turbo, ?injectors, Edge comp, studs and rings. 080 shot NOS
I Beat him by about a truck length, fuel only.
When he would spray, he would beat me by about 2 or 3 truck lenghts...
Id say in total 4 truck lenghts, and thats with some lean mexican nitrous
How much would it drop ET's spraying on my truck?
i believe id have to get studs too...
What difference does it make on ya'll trucks?
Old Oct 12, 2008 | 07:04 PM
dieselrob's Avatar
You wouldnt gain to much untill you put bigger injectors in it.
Old Oct 12, 2008 | 07:08 PM
98.5Hotrod's Avatar
You must have the extra fuel to go with the nitrous.
Old Oct 12, 2008 | 07:15 PM
haloman's Avatar
You can only spray enough NX to clean up the extra fuel you have
Old Oct 12, 2008 | 09:10 PM
97 D-Tec's Avatar
according to NX nitrous in a diesel is nothing like it is in a gas motor. They say you can throw average of a 150 shot before diesels have problems
http://nitrousexpress.com/Pages/diesel_faq.htm
Old Oct 13, 2008 | 06:59 AM
dzlfarmboy's Avatar
I took my 01 24v from 550hp #2 to 790hp on Spray and from a 12.36 to a 11.48 at the track with quite a few dyno runs to tune it that way. So it can make a pretty big improvment but you'll need studs and o rings too prob..
Brett
Old Oct 13, 2008 | 02:52 PM
2whistlers's Avatar
Nitrous is an OXIDIZER. Think of it as an extra turbo pushing more air not as more fuel. You need fuel for it to be beneficial.
Old Oct 13, 2008 | 04:35 PM
12valve's Avatar
i was figuring i'd need more fuel, it doesnt smoke much now at WOT...
I'd like some Mach 4's (waiting on a good deal on a used set)
But im wondering if they would be too small, if i wanna use nitrous??
dzlfarmboy, what size injectors where you running? thats almost a full second which is great!!
Old Oct 13, 2008 | 04:54 PM
rockjeep73's Avatar
my truck with mach 4's and a sps62 would dyno 510 on fuel and 680 on nitrous.
Old Oct 14, 2008 | 10:13 AM
2whistlers's Avatar
Would dyno, or did dyno? What axle ratio do you have?
Old Oct 14, 2008 | 11:18 AM
dzlfarmboy's Avatar
They were Mach 7's with a Pro Street 66 on a Dynojet 248H
Brett
Old Oct 14, 2008 | 11:58 AM
Thedieselkid's Avatar
Brett
How do you tune nitrous on a diesel? I know on a gas engine you will change your timing and check you A/F so you aren't lean.
Just trying to learn.
Paul
Old Oct 14, 2008 | 11:10 PM
rockjeep73's Avatar
"Did", 3.55's
Old Oct 15, 2008 | 06:41 AM
dzlfarmboy's Avatar
Paul
I have a progressive controller that I can change the ramp, amount and there's different jet sizes to try, along with changing your fueling aswell.
Old Oct 15, 2008 | 07:41 AM
I just noticed that yours is a 12V so that will change things a bit also.
